corner clamp
发表于 2021-8-31 22:44:10 | 显示全部楼层 |阅读模式
anyone know where i can get these or something similar?these are from another forum, I believe they are made by Walker Industries.what corner clamp do you guys use? Attached Images
Reply:Here is what I use. These are Wilton brand clamps. I only have two, but someday hope to have four of these.Cost is about $65 each and different brands are available. The center piece swivels to find it's own center. That allows you to clamp 2 different thickness of material if needed into a 90° pattern....... pg
Reply:I just bought one of these:http://www.northerntool.com/webapp/w...2945_200342945its a little expensive, but I love having that 3rd axis for putting tables together
Reply:Bet this would workhttp://www.grizzlytools.com/products...er-Clamp/G8101A butterfly without wings, is just an ugly bug
Reply:Ram Welding Supply.  They are online.  I asked the same question and was able to get a pair from them.  Be prepared- they ain't cheap.  Zimm
Reply:Tractor supply has them..Hobart puts there name on it.
GMT+8, 2025-12-30 00:11 , Processed in 0.096218 second(s), 18 queries .
