查看: 13|回复: 0
Looking for a MM selector switch
发表于 2021-8-31 22:44:09 | 显示全部楼层 |阅读模式
I'm looking for a Millermatic 200 voltage adjustment selector switch. The stem on the one I just picked up is broken off. Thanks.V
Reply:Contact weldersales on this board. He has lots of Miller parts.  That part may still be available from Milller.Millermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:Milky,First of all, welcome to the forum.  Consider listing your location in the CP so folks could know where y'all are at.The Miller PN for the selector switch rotor shaft alone is 005561 which will allow you to repair the switch rather than replace the entire assembly.  However, the entire switch PN is 049280 if you prefer to go that route.  If you need the handle too, that's PN 006927.As crawler suggested, I too recommend you PM weldersales to check with him on availability or where to find any of them as needed.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-30 01:55 , Processed in 0.100616 second(s), 18 queries .
