Anybody build a cup holder?
发表于 2021-8-31 22:44:06 | 显示全部楼层 |阅读模式
I have a 2000 F450 with a bench seat.  I need to put a double cupholder in it.  I don't want to attach anything to the floor because of dogs and seat moving up and back.  I want to be able to hold up to a 44 ounce drink and a couple of cell phones.I was thinking about a bracket that attaches to the center of the bottom of the dash, with a leg back to the firewall.  Has anybody done anything like this?I have looked at all kinds of cup holders but haven't found anything yet that I can mount and look good.Last edited by Crabo; 10-26-2013 at 06:03 AM.
Reply:Look at the cup holders from a 95 era Chevy truck. They add on to the bottom of the dash, and are easy to adapt to other vehicles.
Reply:You could get in trouble driving in New York City with a cup holder that holds more than a 16 oz. drink."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:All the more reason why I have no desire to ever go there.  Have to leave my gun at home also.
Reply:If you're going to make something custom, boat cup holders might work well for the actual cup-holding part.  They're available in white or black plastic or stainless and usually fit in a 3.5" hole.  They also make some pre-made double units that are basically two of those in a block wrapped in various colors of marine vinyl with different mounting options.
Reply:Get bucket seats with a center console.My 03 X has two cup holders in the center console as well as pull out two cup holder deal in the dash.
Reply:Originally Posted by VPTGet bucket seats with a center console.My 03 X has two cup holders in the center console as well as pull out two cup holder deal in the dash.
Reply:Check out Ram mount cup holdershttp://www.rammount.com/CatalogResul...5/Default.aspx
Reply:Just cut a hole in the floor. Then you also have a place to spit your rub!
Reply:Originally Posted by TIGguyJust cut a hole in the floor. Then you also have a place to spit your rub!
Reply:Originally Posted by CraboDon't want to give up the bench seat.  It's a single cab and need all the room.
Reply:Mount it to the bottom of the seat to the metal frame and run a support out to attach the cup holder. That way it moves with the seat and will be more stable than on the dash.
Reply:Is this an automatic truck or manual?
Reply:Curious, what is in the standard super duty cup holder spot on the 450?
Reply:I bought one at pep boys for .99 cents for my old F250. It went into the window channel and hung there. Worked great for years. That truck is in PA now by dads. I bet it's still in it.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:scroll down on this page , fella made one for a VW that replaces ashtray ,  might be something to germinate some ideas  http://weldingweb.com/vbb/showthread.php...projects/page5
Reply:I like the seat frame idea.Moves with the seat, can be placed between the driver and center passenger.  Could fit 2 cup holders one infront of the other instead of side by side.You would still have room to seat 3 people, and it would place the cup holder right about where your hand would naturally fall.  Give yourself a week you would never half to look to grab the cup or put it back.
Reply:Originally Posted by VPTCurious, what is in the standard super duty cup holder spot on the 450?
GMT+8, 2025-12-30 00:10 , Processed in 0.097021 second(s), 18 queries .
