Been weird weather lately.Had a Honey DoShe and I liked the milk can, she bought it, I had to paint it.Got a start on a new cart for the LN25 & PlasmatronAt this point right now, ready for the axle.Tie downs will attach on the underside of the pan for each machine. I generally use small ratchet straps to hold stuff on these carts.Should have the axle on this afternoon, supposed to rain all day tomorrow"Any day above ground is a good day"http://www.farmersamm.com/
Reply:A fine work in progress!PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Kelly sure has the place looking mighty fine Samm!Need to get back up that way for another one of those great steak dinners. I forget the name of the place but sure enough was everything you said it was.Did you say you were buildin' something? MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:It not too late for a simple redesign Sambo. Maybe just a tweak to get everything down to a good fit for those old bones? Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Woefully little has been done on this thing in a while, finally got back to it yesterday late afternoon.Axle fitted and welded, and set up for measuring the height of the front legs. Should about kill it today. Got other stuff that needs doing.Long as it's been sitting outside the rust will match just about everything else around here"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by tackitNice ramp and railings too Sam. How's the new hood?
Reply:Originally Posted by ThorsHammerit's right there in the grass, what? can't you see it?
Reply:Well, it are doneInstead of a blow by blow, I thought I'd just pass on some highlights for general info.Axle mounts, and frame gussets. Nothing fancy, just some scrap 3/16 plate. Note that the axle is just locked in place with a small weld. No need to weld the entire circumference Plasma worked fine for the 12ga sheetmetalI used to make a lot of furniture, this is a furniture tip If you're able to.......do a "reveal".....do it. It's simply a step back from the edge of where you're attaching sheet goods to a frame. It allows you to align everything easily, and it looks very neat without stressing over matching the edge of the frame exactly.After the bulk of the cart was done, it was time to put the stuff on it, and determine where I needed hangers, hooks, etc........"Any day above ground is a good day"http://www.farmersamm.com/
Reply:My Motorgard filter has always been attached directly to the back of the plasma, and I decided to move it to a more convenient place, and get it out of the way of my foot when I had to tip the cart to wheel it somewhereMade a sorta custom bent thingy to hold the filterFilter fits real nice in the forks, and a hose clamp is used to secure itWelded to the frameI need a narrow profile in order to wheel the thing down a narrow corridor. So the cables etc, have to be stored inside the wheel stance. For this reason the cables are stored on these hooks Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:The hook assembly that blocks the door on the LN25 has to swing out of the way to load wire etc.So anyhow..................... this is how it looks when it's all put togetherGotta prepare for old age I guess, time to put this crap on wheels, and save the back"Any day above ground is a good day"http://www.farmersamm.com/ |
