Hanging SA 250
发表于 2021-8-31 22:44:04 | 显示全部楼层 |阅读模式
Taking my skid out of the truck, guess I rigged it too far out on the forks. Made for one hell of a ride. Sent from my HTC One X using Tapatalk Attached Images
Reply:That's what they make separate wheel brakes for. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I am not the only one with an SA250 in the front yard now......Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Funny, I moved it in the garage. Want to move up to a pipe pro 350 tired of the super heavy machine. Don't really want a duley.  Sent from my HTC One X using Tapatalk
Reply:I'll bet there was a wet pucker mark on that tractor seat that resembled this * after that ride! Good save! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeI'll bet there was a wet pucker mark on that tractor seat that resembled this * after that ride! Good save!
Reply:Originally Posted by duaneb55That's what they make separate wheel brakes for.
Reply:Originally Posted by SquirmyPugLooks like you need a bigger tractor DF, or maybe some counterweights
Reply:Guess next time I should pick up a round bale with the forks on the front. Letting it down was the scarry part thought the top link was going to let go for sure. Don't want to do that one again. Sent from my HTC One X using Tapatalk
Reply:It's not a small tractor too it weighs 9k lb and dynos at 90hp Sent from my HTC One X using Tapatalk
Reply:Ha Ha. Only a Hoosier would dyno a tractorSafety 3rdGump
Reply:Yeah, that's betting it all on a little.A crash landing could be a total disaster.. . .Take out the steer axle, welder, tilt cylinders, attachment on the radiator end. . .Last edited by denrep; 10-23-2013 at 11:09 PM.
Reply:Yikes!!!  Be careful man! I think we figured out in another thread that upright was off an old Clark Walkie Stacker.  That is probably only rated 2000 lbs at a 24" load center.
GMT+8, 2025-12-30 00:29 , Processed in 0.074220 second(s), 18 queries .
