55 ford truck seat mounts
发表于 2021-8-31 22:44:04 | 显示全部楼层 |阅读模式
Wanna fab up some seat mounts for my 55 truck.  I have 2 bucket seats that i wanna use.  A 2x4 is just the right height for the seat to be where i want it to be.  Here's some pics, What do you guys think i should use and what kind of pattern?  1 inch tubing?  angle iron?  here's some pics...
Reply:The last one I did was an air ride seat in a big truck. I used flat stock bent to shape. Then welded "sides" to make a U where needed.I used the bent flat stock to scribe the sides for cutting.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-30 00:29 , Processed in 0.099154 second(s), 18 queries .
