First Tig attempt
发表于 2021-8-31 22:43:58 | 显示全部楼层 |阅读模式
Here is my first Tig attempt.1/16 2% Lanthanated tungsten50 amp DC no fillerI forgot to put a dime in pic for scale, but the piece is 2" of 1 1/4" 14ga tubing with a small 16ga strap welded to the the top. Attached Images
Reply:Looks good. So you got it fixed?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Yeah thats fine........  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by shovelonLooks good. So you got it fixed?
Reply:50amps is a little low but it looks good. Next time try to get the weld started closer to the edge of the steel, you can see a little that isn't welded.  I'm glad to see you and some of the other guys new to tig actually cleaning the steel before welding. Guess everyone telling the new guys to grind off the millscale is starting to sink in Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
GMT+8, 2025-12-30 00:29 , Processed in 0.103990 second(s), 18 queries .
