Finally.......
发表于 2021-8-31 22:43:57 | 显示全部楼层 |阅读模式
Well after ten weeks the swimming pool lift guys got some work for me.......Their going after the private residence customers now and have a couple new parts in the works.....these will mount on top of a cement pedestal for above ground pools with high sides...Love the Dynasty with way more power than necessary for 1/2 in. plate....Last edited by B_C; 07-24-2013 at 10:07 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:You get all the fun jobs....Not too flat anymore are they...Oh well happens all the time......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Hey Zap, no they warp a bunch until I put a thick flat washer in the middle and bolt another plate together with it.....Still get some movement but the red head bolts pull it flat when their installed.......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Good to see you got some work from them Bill. Ya know ya likes the aloominooom.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:That's some nice lookin work Looks like a lot more fun than the .060" aluminum I did last time...been itching to crank up my Airco and let it eat some electricity  Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice.I hope they don't spill any chlorine powder on that aluminum... Will they be putting some kind of gasket or coating between the aluminum and the concrete post? I've found (with alum alloy boat skegs) that the lime in concrete will eat into aluminum in a humid/dewy environment.
Reply:BC, what amperage does it take to weld those with your 350?
Reply:Well lets see what do I use on the 1/2 in.......  I think I had it set at 240 amps 100Hrtz.72 Bal.  and the amplitude was 1.2%  1/8 2% Lanthinated  Gas lens 6 and 3/32 4943filler....Oh and 25% Helium Argon....Pulse the pedal.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by KelvinNice.I hope they don't spill any chlorine powder on that aluminum... Will they be putting some kind of gasket or coating between the aluminum and the concrete post? I've found (with alum alloy boat skegs) that the lime in concrete will eat into aluminum in a humid/dewy environment.
Reply:Originally Posted by KelvinI hope they don't spill any chlorine powder on that aluminum...
Reply:Originally Posted by B_CWell lets see what do I use on the 1/2 in.......  I think I had it set at 240 amps 100Hrtz.72 Bal.  and the amplitude was 1.2%  1/8 2% Lanthinated  Gas lens 6 and 3/32 4943filler....Oh and 25% Helium Argon....Pulse the pedal.....
Reply:Great stuff!To keep the warp down you did the best you can do. However if you do allot of these pick up a 1" (or more) thick plate and drill/tap the corners for the bolts. Like you did stick a washer in the middle and bolt the corners down to the plate. I have had GREAT luck strapping everything down to super thick stuff while welding. My favorite is a rail section.
GMT+8, 2025-12-30 00:24 , Processed in 0.100077 second(s), 18 queries .
