welding parimerters 70s3
发表于 2021-8-31 22:43:57 | 显示全部楼层 |阅读模式
could some one get me the setting for .062 70s6 Please thanksLast edited by coreshield8; 07-31-2013 at 11:50 AM.
Reply:Hello coreshield8, try this link. I believe the information you are looking for is here. Best regards, Allanhttp://www.unibraze.com/DataSheets/Data70S-6.pdfaevald
Reply:Go to ESAB or Lincoln's website (or whatever wire vendor you happen to be using) and look it up.  Both list some 0.062 (aka 1/16" aka 1.6mm) solid steel ER70S(3/6) wire in spray transfer mode at about 27-29V and about 300-400 amps and about 200-300 ipm WFS.  Slight variation depending on what shielding gas you are using (C10 vs 98-2, etc,) etc,  etc.  The best laid schemes ... Gang oft agley ...
Reply:Thank you Guys
GMT+8, 2025-12-30 00:29 , Processed in 0.100551 second(s), 18 queries .
