Petrogen Oxy-Gasoline cutting torch
发表于 2021-8-31 22:43:57 | 显示全部楼层 |阅读模式
Ebay ad...sounds dangerous!http://www.ebay.com/itm/Petrogen-Oxy...30974422037%26
Reply:Those torches have been covered several times here. They have some limited advantages in certain situations, but take a fair amount of maintenance. We had one when I worked for the commercial dive company, but we almost never used it due to the hassle compared to simply running exothermic rods or standard OA.The add is also just for the gas can. You still have to get the torch, hose and other parts..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I work for the fire department and they got suckered into buying them. O/A is much more versitle. I wouldnt buy one.RG_______________________Hobart 187Northern Tool Plasma 375Harris 85 O/A Rig (Ireland)
Reply:The guy in his eBay listing says nitrogen is a common fuel! Sent from a Braniff 707 via telex1980 Lincoln SA-250.1521976 Lincoln R3S-6001978 Hobart G-213Hobart Titan 8TA Hefty 2Thermal Arc 211iCutmaster 42
Reply:Nitrogen is inert and wont burn. Hes had a little too much peyote while writing his add. Or hes just full of bull.RG_______________________Hobart 187Northern Tool Plasma 375Harris 85 O/A Rig (Ireland)
Reply:Dunno, would it be better to use oxygen to pressurize the gasoline for delivery?XMT304 (school)SP125+ (home)HF 4x6 BandsawGood judgement comes from experience and much of that comes from bad judgement.
Reply:Originally Posted by wireheadDunno, would it be better to use oxygen to pressurize the gasoline for delivery?
GMT+8, 2025-12-30 00:30 , Processed in 0.099502 second(s), 18 queries .
