d6r repair
发表于 2021-8-31 22:43:55 | 显示全部楼层 |阅读模式
here are the rest of the pics thanks Attached Images
Reply:Pretty dern ingenious set up there. Took me a minute to figure out what was going on. . Pretty slick. Thanks for the pics.
Reply:Take that Cat!!Approximately how long does it take to set up a rig like that and how do you find/re-establish the correct bore centerline?Awesome work Steve.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Approximately how long does it take to set up a rig like that and how do you find/re-establish the correct bore centerline?
GMT+8, 2025-12-30 00:29 , Processed in 0.070494 second(s), 18 queries .
