Cat D6R hardbar and dozer frame repair
发表于 2021-8-31 22:43:54 | 显示全部楼层 |阅读模式
Heres a few pics of a hard bar it was egg shaped about 5/8 pon 2 sides in bearing fit i hand welded it up 1/8 7018. then linebored and cut snapring grooves back in it. The dozer frame is 4140 and from cat has no bushings i take two bushings from the hardbar and bore the frame for them. cat pulls the motor or oil pan to do this but joint gives enough room to bore thanks for lookin steve Attached Images
Reply:Nice work. Heavy work I'll bet. How do you get the bar from the truck and into place? Backhoe maybe?
Reply:Originally Posted by SandyNice work. Heavy work I'll bet. How do you get the bar from the truck and into place? Backhoe maybe?
GMT+8, 2025-12-30 00:29 , Processed in 0.072302 second(s), 18 queries .
