Lindberg Heat treat furnace with honeywell controls
发表于 2021-8-31 22:43:51 | 显示全部楼层 |阅读模式
Hello, What we have here is a Lindberg heat treat furnace, it is quite large, exact weight and dimensions (outside and actual oven volume) to follow soon.Here is a bit of a disclaimer and the story behind this monster, This machine is very simple but I cannot guaranty that it works.It worked when it was taken out of service at Allis-Chalmers in West Allis, WI 8 years ago. So if you have a need for a larger heat treat furnace and know what you are doing, this could be a steal.After contacting Lindberg, I know that parts are available, and that they want around 300 dollars for the manual, the engineer said the price was high because each one of these furnaces was built to customer specs, they have records on this machine and it would cost me to get them, thanks guys.It currently resides in the 53189 area code that is where it would ship from, shipping arrangements must be handled by the purchaser. I will of course make sure that it is packaged to your specs and loaded on the truck but thats it, I do know that I will have to rent a forklift to put it on the truck because ours does not lift this thing.So there ya have it, I thought I would post some general info and pictures to see if anyone was remotely interested.If you are PM me with any questions. Attached ImagesYup
GMT+8, 2025-12-30 00:10 , Processed in 0.069808 second(s), 18 queries .
