Has anyone built a plasma beveling machine?
发表于 2021-8-31 22:43:40 | 显示全部楼层 |阅读模式
Has anyone built a beveling machine for pipe that will hold a plasma torch (handheld or machine type)? I have some pipe up to 8" that is going to get cut up for practice. I could cut and bevel in the lathe which would be the easy way, but I'm looking for another projectTOO MANY TOOLS & NO MORE SPACE
Reply:Never heard of it being done. But my experience isn't vast, or even existent, per se. But I would love a machine beveled pipe over flame cut.
Reply:Just build a set of pipe rollers, then build a torch holder to hold the torch at an angle. Turn on the torch and roll the pipe.
Reply:Here are three of many offthe shelf pipe / tube cutters. The first is from AKS in Cleveland,   a machine cable of cnc cutting of square rectangular and round tube....also can contour bevel flat plate. Second is  a Vernon Tool pipe cutting and bevelling machine, Vernon is owned by Lincoln Electric and is built in the same building as Torchmate in reno NV, third is a portable pipe cutting machine that holds a plasma or oxy-fuel torch.Jim Colt  Hypertherm Originally Posted by Chris T.Has anyone built a beveling machine for pipe that will hold a plasma torch (handheld or machine type)? I have some pipe up to 8" that is going to get cut up for practice. I could cut and bevel in the lathe which would be the easy way, but I'm looking for another project
Reply:Walker, that would be the simplest way of doing things as I'm only thinking of this for my home shop. Just don't know how I could hook up the ground. Maybe something like a rotary positioner uses?Jim, do you have any info on the last device? I cant really tell how it is held on the pipe but it looks pretty cool.TOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by Chris T.Walker, that would be the simplest way of doing things as I'm only thinking of this for my home shop. Just don't know how I could hook up the ground. Maybe something like a rotary positioner uses? . . .
Reply:There are a few companies that make portable pipe beveler/cutters, one is H&M, here is a link:  http://hmpipe.com/machines/band-type-bevling-machines/Jim Originally Posted by Chris T.Walker, that would be the simplest way of doing things as I'm only thinking of this for my home shop. Just don't know how I could hook up the ground. Maybe something like a rotary positioner uses?Jim, do you have any info on the last device? I cant really tell how it is held on the pipe but it looks pretty cool.
Reply:Just get the hand crank rotary torch beveler and get the plasma attachment
Reply:justinT, unfortunately I can't justify that expense just for hobby use. I like the roller idea and have been doing some napkin sketches. This is something I definately don't need, it would just be a cool little project.TOO MANY TOOLS & NO MORE SPACE
Reply:@ Chris T - Surf to www.ljwelding.com and access the 'manual welding positioners' and 'pipe stands' links.  Options for driving (rotating) and holding the workpiece for plasma & O/A apps.  With a reduced budget in mind, you could simplify both the hand-crank assembly and roller pipe stands. The stow-away feature of the pipe stands would, however, be a desirement for me.Great projects to build. Good luck!"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
GMT+8, 2025-12-30 00:10 , Processed in 0.168801 second(s), 18 queries .
