Bernard or similar TIG water tank wanted
发表于 2021-8-31 22:43:33 | 显示全部楼层 |阅读模式
Anyone have a used, relatively small water tank and circulating pump for my TIG. The power lead bit the dust and part of the trouble is my present Bernard tank and pump is part of the problem. Any recommendations on the best bang for the buck on a new tank and circulating pump? The machine is in a home shop and I run it on the middle current range 95% of the time, so a small tank is adequate.Thnks,Chuck
GMT+8, 2025-12-30 02:03 , Processed in 0.102831 second(s), 18 queries .
