EBAY had a Miller 300 listed a day ago. Guy wants $500! At this price there are a couple catchs. Seller has no history with the machine nor is he a welder so he cannot / will not confirm that it works. The other issue - my complete lack of TIG experience. I am learning welding to help my car project along. I have rust repair projects I want to finish before winter and can see more difficult projects in the future for when my experience grows. I was looking for a nice MIG machine and normally would not consider a machine like this if not for the price. My assumption is that something is wrong with this machine. I have the opportunity to inspect it in person. Short of welding with it (no TIG experience - should I even try to strike an arc?) are there any visual tests to rule some problems? For example does turning it on prove anything? Of course I will open the case and look for burnt up wiring or smoke damage. If I find something nasty I can walk away. Can you spot failures in a visual inspection? Second - This is a LOT of machine I know TIG is harder than MIG (I have tackled a couple small projects with my little MIG - not bad given its a no name 110V machine) I know TIG is slower but not a big deal for me, I am not on the clock and none of my projects will require that much welding individually. I am attracted to TIG because of the super nice results that are possible. Of course - it will take me awhile to get there. I know most of you are pros and questions like these will annoy most of you - please take it easy. Tom
Reply:The first thing to look at, see if the machine is 3-phase only. This is common with welders of 300 amps or more, and its a common reason they are cheap.
Reply:There are TWO of the Syncrowave 500 machines on http://www.govliquidation.com/ web site right now. Bidding stands at $460 for both. Auction ends 10/28 at 5:00 p.m.Item location is Mechanicsburg, PA.
Reply:Originally Posted by Q W & F L.L.C.Those may go super cheap. They are highly sought after by certain users. I would bid in a second, but not in the cards for me at the moment. Thanks for sharing, a great deal for someone. S.W.
Reply:Two Syncho 500's for $426 (next highest bid amount). Single phase input, but it needs ~200 amps input at 230V!That and they weigh ~900 lbs EACH (1800 lbs for the pair on the pallet)! The best laid schemes ... Gang oft agley ... |
