Does anyone got roller chain laying around.
发表于 2021-8-31 22:43:31 | 显示全部楼层 |阅读模式
I need only 1ft. of #40 (1/2 pitch) roller chain(new). Every where i look it only comes in 10ft lenghts and the shipping is a killer. So if anyone has some spare roller chain ( for a good price) all i need is just 1 ft. because i have the rest of #40 that i need. Thanks alot
Reply:Give me a bit and I'll check for you.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:A supplier up the street from me sells it by the foot, I will see what he gets for it, or you can call him. Capeway Bearing and Machine in Plymouth MA, 508-747-2800, I am sure he will UPS you what ever you want.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Sorry - only #41.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:2 jobs ago I would send a piece but now days 60 is the smallest I deal with. Mcmaster-Carr used to sell it by the foot. HTML Code:Mcmaster.comTough as nails and damn near as smart
Reply:If you can help it, try to buy US made chain.  The foreign stuff is really bad.  Permatex makes a product called Motorcycle and farm something or other lube for roller chain.  It is about the best out there.  I have chain that's over 5 or 6 yrs. old runnin' in really dusty cruddy environments that still goes to work in the Summer.  The guys that run ag lime trucks use it too.  It's really good stuff.  Comes in a spray can."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Sorry we only have 80,100, and 120.  TSC usually has some chain.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Try TSC or Lowes.  They both have/had chain, at least around here.  It's in the usual 10 ft lengths, but at least you're not having to pay UPS to deliver it.  You just have to go to the store and buy it.  I found some #60 marked down at Lowes a while back, less than $1.00 per foot for the 10 ft length.  So I bought it.    The best laid schemes ... Gang oft agley ...
Reply:Around here, you can by industrial/ag grade #40 chain for 11.00 a 10 foot roll.Sounds pretty cheap and is cheap as any shipping would cost.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-30 02:03 , Processed in 0.120306 second(s), 18 queries .
