new toy for rig.
发表于 2021-8-31 22:43:30 | 显示全部楼层 |阅读模式
Pick this up last week.it,s a ekgard/Dakota 6000lb cap.12' closed hyrauilc out to 16' and a 2' pull section so 18' overall.Pto driven ,branden winch,360 continuous rotation,hyraulic outriggers up and down manual pull out,chlsea pto,commercial intertech pump. Attached Images
Reply:Anybody recommend a resoivior/tank size could not get out of old body came from was part of the ub.
Reply:What's the measurements of the ram?  I would take that volume and at least double it.  More fluid is always better from a cooling standpoint.
Reply:If it doesn't have a reservoir I would probably just throw it away. I am such a nice guy I would get ride of it for you and you wouldn't have to do anything with it. Just let me know when you want it out of you way. I would hate for you to trip over it. I am just thinking of you and your safety.
Reply:Originally Posted by JeffKiperIf it doesn't have a reservoir I would probably just throw it away. I am such a nice guy I would get ride of it for you and you wouldn't have to do anything with it. Just let me know when you want it out of you way. I would hate for you to trip over it. I am just thinking of you and your safety.
Reply:Originally Posted by admsweldingPick this up last week.it,s a ekgard/Dakota 6000lb cap.12' closed hyrauilc out to 16' and a 2' pull section so 18' overall.Pto driven ,branden winch,360 continuous rotation,hyraulic outriggers up and down manual pull out,chlsea pto,commercial intertech pump.
Reply:I like it, I wish my AutoCrane had power outriggers, cranking sucks.
Reply:Originally Posted by chevyrigIm not sure what kind of truck/body your puting this on but i mount these were i work.Make sure you build up the box or tie it into truck frame really well. Ive seen some people just throw them on a side box and just weld a 3/8 plate on the top and a few square tube supports and mangle a nice tuck. Im not in no way implying you dont know what your doing just trying to give u a tip or heads up. The bodies we use at work have a heavy duty under body set up. Have fun with it they are really useful for just about every thing. and looks like u got a good one. we mount liftmore cranes from the little pick up ones to the big international service trucks.
Reply:Originally Posted by admsweldingHere is a pic of the truck its being mounted to.When I built this deck the 4" channel cross braces changed from the front of the rear tire back from 16"o/c  5.4lb/ft channel to 6"o/c 7.25lb/ft channel.Think I be ok?There is a 1/2"plate on p-side rear corner 21"x24" I,m building my mount box onto of that.
Reply:Originally Posted by chevyrigthat sounds like it will work. how are you going to do your outrigers?
Reply:Originally Posted by admsweldingGonna tie p-side into frame then into underside of deck.Will be able to slide out this side d-side will be stationary.Planned on using all hss sq tubing probably 4x4x.25 and 3-1/2x3-1/2 x.25
Reply:Adams, please show pics of how to mount this into that little truck. I know you have a fleet of big trucks, but I need ideas for my rinkydink lift onto my rinkydink dink Dodge. When I say rinkydink dink, I mean I can literly dent the body or bed using my thumb.Structural help is needed thanks
Reply:Got some paint on it tonite here first coat will get pic tomorrow of finish coat.Also picken up steel tommorrow to start mounting platform next. Attached Images
Reply:Here a pic of the final coat of paint.And the start of the build.All 4"x4"x1/2" angle.20" legs down to the deck plate.Pic of the cross members under deck,under the 20"x24"x1/2" deck plate
Reply:more pics.Need to mount outriggers,mount door to compartment under crane valvebody to control outriggers, and flow/ divider/regulator will be inside there, along with remote as pictured.Ordered steel to build hydro tank today will pu later this week.Also need to pu my pto had to have gears changed to adapt to my tranny. Attached Images
Reply:Pics of the oytriggers.P-side mounted it,s welded to outer rail also for strength.D-side cut thru outer rail to allow to slide in/out.And the d-side rigger on shop floor unmounted. Attached Images
Reply:Looking good, I still have to stop by one of these days.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingLooking good, I still have to stop by one of these days.
Reply:Both outriggers are mounted now.Picked up pto and pump gears are all set need to install mount pump on back of pto.Pick up steel for tank and get building tank and plumb this thing up.
Reply:pto is mounted had to chop out some excessive tranny material to get pump on but got it.Tank is on bench fabbed,waiting for tank fittings from McMaster carr.P-side out rigger is in. Attached Images
Reply:Should have let me know what you needed for tank fittings, I may have them in stock. Met Pipe in Cambridge has most of that stuff too.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingShould have let me know what you needed for tank fittings, I may have them in stock. Met Pipe in Cambridge has most of that stuff too.
Reply:You need everything in 3/4"? If that is the case I have 3" nipples ,90's and what not in either sched 40, SS, or weldable steel.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Feed line and return is 3/4".Fill port and suction 1".Could use about 4 -3/4" 90,s 2 -3" nipples,2-3/4" couplings threaded sch.40 if you got it.Can grab a few 6' of pipe at home depot.Thanks will save me a little $$$.
Reply:Couple of pics of it all mounted and running. Attached ImagesYour rig looks good If you made the platform the bottles sit on slide up and. down         maybe with pipe inside of pipe with a spring loaded latch to hold it up you can use the crane hook to raise and lower the platform to the ground. To roll bottles on and off. Might not be worth the work if you carry the small oxygen I carry two large 250 oxygen there a little more awkward.
Reply:Originally Posted by admsweldingCouple of pics of it all mounted and running.
Reply:Originally Posted by Nick DYour rig looks good If you made the platform the bottles sit on slide up and. down         maybe with pipe inside of pipe with a spring loaded latch to hold it up you can use the crane hook to raise and lower the platform to the ground. To roll bottles on and off. Might not be worth the work if you carry the small oxygen I carry two large 250 oxygen there a little more awkward.
Reply:Originally Posted by admsweldingI just tossem on and off.I don,t want to start being lazy I,m still young enough.Where you from nick I see you live in mass near me?
Reply:Originally Posted by Nick DYea I hear you the small ones aren't  that bad I like to use the large oxy bottles seems like a better match with small acetylene I live in Peabody I have another trash compactor job off Montvale av. Stoneham tomorrow.
Reply:Originally Posted by admsweldingWhere about I stop by my shop right up street.
Reply:That's a great looking rig.IW Local 580 NY, NY
Reply:Originally Posted by Nick DThe jobs at 100 ledgewood drive If I don't see you Il drive by your shop on the way home.
Reply:Nice truck, I like how the crane sits close to the toolboxes and not sticking way up in the air.TOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by Chris T.Nice truck, I like how the crane sits close to the toolboxes and not sticking way up in the air.
Reply:Originally Posted by Nick DYea me to my rig looks a little top heavy il remember that for my next rig.
GMT+8, 2025-12-30 02:03 , Processed in 0.310228 second(s), 19 queries .
