Maple Sugaring arch Build "Pic heavy"
发表于 2021-8-31 22:43:29 | 显示全部楼层 |阅读模式
Built this new arch for a customer whom I also help during the sugaring season. His old arch is only one season old but had a multitude of problems so its going back to the company that built it. I did however reuse their door so I can't take credit for that part. I just had to make it fit the new arch. The old arch warped and leaked smoke from everywhere as this is a wood fired force draft setup. On the new setup the fire box is larger and I doubled the blow through fire grate area. All the frame work is 1/4" steel. First pics of the old one and then the build. Sorry for the close pics but I was in tight work space. I'm very pleased with the outcome since it was built on site and on the floor. Built most of it with my TB 302 and a little mig work with a hh 185. Thanks for viewing-Keaton Attached ImagesLast edited by KD Welding; 11-05-2013 at 10:50 PM.
Reply:Getting started Attached Images
Reply:little further Attached Images
Reply:Got the old door fitted on Attached Images
Reply:Got rid of the mill scale and added some high temp stove paint Attached Images
Reply:All done its ready for fire brick and insulation Attached Images
Reply:Where did you find the stainless tub? Need to build a cooker before we tap this spring. Sent from my HTC One X using Tapatalk
Reply:That isn't a tub. That is the back pan is 30"x9' raised flue pan. How many taps you going to put out?
Reply:I still have no idea what it is or how it works or what it does.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11I still have no idea what it is or how it works or what it does.
Reply:That whole setup looks unsanitary. I am constantly freaked out by the things I like to eat and where they come from or how they are made. Make more. I like it all over my biscuits and gravy!!!!!!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-30 02:04 , Processed in 0.096050 second(s), 18 queries .
