Reduce the metal distortion due to welding effect
发表于 2021-8-31 22:43:28 | 显示全部楼层 |阅读模式
Hi all,Can somebody suggest me how to reduce the metal distortion during welding?Due to production requirement, we connect some brackets to flange and apparently the flange bend.FYI, e are currently applying flux core type (all parts are fully welded).Thanks.
Reply:Study the link above for starters.Since your query doesn't provide any pics or relevant information, the resultinganswers you get may not apply.Blackbird
Reply:Really old video, but still has some good info.Lincoln Pro Mig 180Lincoln Pro Core 125Hypertherm 30xpPorter Cable Drill PressAcra 7x12 bandsaw48" sheet metal brakeCrap load of other tools, working on metal now.
Reply:If you're doing a bunch that are the same, see if you can bolt the flanges back to back to control distortion. If that's too awkward, bolt a blind flange or cut a plate to bolt on. If you're applying a lot heat things are going to pull.
Reply:Two good rules to live by to help prevent distortion:First rule, back step all your welds!Second rule, skip around a lot!Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:When I'm fabricating, I make all kinds of extra tack welds to hole my pieces in place then going off the extra tack welds when I'm complete and the part has cooled. This works real well when fabricating on the welding table.  If you can't add extra tacks, you can always add extra clamps/cgrips etc to hold things in place and prevent distortion. I've also welded extra steel to things to keep things square etc and prevent distortion while welding. Then grind off the extra steel used for bracing after the part has cooled.Last edited by snoeproe; 02-13-2015 at 07:33 AM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-30 01:54 , Processed in 0.108224 second(s), 18 queries .
