6010 downhill hotpass, what do you think?
发表于 2021-8-31 22:43:26 | 显示全部楼层 |阅读模式
1/8" 6010 6" sch. 40 pipe all feedback is appreciated
Reply:I dont have the most experienced in the world hell im still in welding school but TO ME it looks like you were moving a little too fast especially at the top. Looks like you slowed it down a bit at the end. Please someone correct me if im wrong then youll be teaching 2 people something
Reply:Thanks! i'll slow it down a bit. i was running pretty damn hot so i thought i should move pretty fast.
Reply:Watch the weld pool bro. Like i said im a newb also but i bug the HELL out of my instructors for any knowledge i can. The hard part is applying the knowledge lol
Reply:For sure man. I'm used to welding 12" pipe really hot and really fast with larger diameter rods. For some reason this smaller pipe and smaller diameter rods are hard to get used to. It's just a matter of adjusting though. UA Local 250
Reply:I think on a pipeline, they would have used a 5/32" rod, maybe even 3/16". My former neighbor was a really good pipe welder and I was watching him try to set up his new diesel Lincoln Classic. He liked his 57 short hood better but sold it for $5500! He ran real hot but his bead widened out more dragging it straight down on a flat plate. I think you might be a little too fast or need a slight weave so you don't get slag inclusions on the edges. A 5/32" rod would probably wash out to the sides more. The machine you use can make a big difference too on downhand pipe welding.
Reply:Yeah, 5/32 root and hot pass and 3/16 filler and cap (6010 or 8010). That's how I weld out 12"UA Local 250
Reply:Thanks for your input bro! Much appreciatedUA Local 250
Reply:I'm on a miller CST 280 right now, I haven't been able to use the SA 200 UA Local 250
Reply:No problem. I love this stuff man!
Reply:Originally Posted by Welder Dave; on downhand pipe welding.
Reply:show the inside ... that is what matters.AWS CWI xxxx21711968 SA200  Originally Posted by WelderMike  I hate being bipolar, It's awesome.
Reply:Originally Posted by AFFENDEshow the inside ... that is what matters.
GMT+8, 2025-12-30 02:04 , Processed in 0.092095 second(s), 18 queries .
