Bending square tubing steel
发表于 2021-8-31 22:43:23 | 显示全部楼层 |阅读模式
I am looking to pick up a machine that can bend square tubing like the upper tube in the picture below.It has sort of complex curves.What kind of machine would be suitable for this type of work?
Reply:How many times you got to ask the same freaking question?If you'd get your head out of your azz and read a few posts (much discussion on this exact subject here lately) you'd know you're looking for a roller.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by SundownIIIHow many times you got to ask the same freaking question?If you'd get your head out of your azz and read a few posts (much discussion on this exact subject here lately) you'd know you're looking for a roller.
Reply:Originally Posted by pyroracing85sand in your vagina?
Reply:Originally Posted by pyroracing85I am looking to pick up a machine that can bend square tubing like the upper tube in the picture below.It has sort of complex curves.What kind of machine would be suitable for this type of work?
Reply:dave why is this ok
Reply:Ranger 250 GXTSmith Gas Axe
Reply:As others have eluded, this is a Roll Bender you need. Allows you to roll the radius through a series of passes through the rollers.If you have asked this question before, and it has been answered, I understand why the other poster responded as such.Granthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:You could also use a Hossfeld Bender with feed along dies.
GMT+8, 2025-12-30 02:23 , Processed in 0.089811 second(s), 18 queries .
