flex head tig torch
发表于 2021-8-31 22:43:20 | 显示全部楼层 |阅读模式
I was welding some stiffening plates on the ribs of my boat todayand I figured out that its pretty hard to run the foot pedal with myknee while bent over trying to weld. After a few cuss words and saying this is stupid, I decided to just stand on the garagefloor and reach over the side and do it. Work smarter not harder right.Being limited to only so much room to get in the right positionI remembered I have a flex head torch duh... After only two timesadjusting the flex head, it flexed right off. Broke right at the head,I could see the copper tube in half. That sucks, right in the middle of a project .Any way for a easy fix or just get a new one?Iam also wanting a torch longer than 10'. Will any torch workor does it have to be a lincoln tig 225 torch 17 series?      Thanks.          James
Reply:Should be able to buy a new #17 torch and put it on the hose/cable. Since you want longer it would be easier to buy a new torch/hose like you want to connect it to your welder and be done.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:http://stores.ebay.com/welders4less/...&_sid=25081211Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Thanks squirmy pug I didn't know if weld craft,ck or other brands are compatible.Just replacing it would be easier, just want longer hose though.
GMT+8, 2025-12-30 02:24 , Processed in 0.074682 second(s), 18 queries .
