5000W Generator $350, Boston Area
发表于 2021-8-31 22:43:18 | 显示全部楼层 |阅读模式
This is a DeVilbiss GT5000 generator. 5000 watt rated output power, 6250 watt surge. 120/240VAC Excellent condition. Used four times.Clean electricity suitable for radios, televisions, computers, and other sensitive equipment. Plus refrigerator, sump pump, well pump, tools, etcIndustrial quality alternator – premium brushless design with ball bearing construction for extended lifeExtra large 7 gallon tank available for run times up to 10.8 hours10HP Tecumseh engine with cast iron cylinder sleeve and low oil shut down for long engine life120/240 Volt output up to 25 Amps..............$350 Must Pick Up508-525-0367 or [email protected] BDartmouth, Mahttp://www.rvbprecision.comMM 185 MIGDiversion 165Purox W200 O/AGrizzly 9957 MillGrizzly 4030 Metal Band SawGrizzly 1050 Knife Belt SanderJet 1236 Metal LatheCM 14" Metal Band SawTP Blast Cabinet
Reply:SOLD!Roy BDartmouth, Mahttp://www.rvbprecision.comMM 185 MIGDiversion 165Purox W200 O/AGrizzly 9957 MillGrizzly 4030 Metal Band SawGrizzly 1050 Knife Belt SanderJet 1236 Metal LatheCM 14" Metal Band SawTP Blast Cabinet
GMT+8, 2025-12-30 02:24 , Processed in 0.072667 second(s), 18 queries .
