Air tank wheels, and smoker stack add on
发表于 2021-8-31 22:43:13 | 显示全部楼层 |阅读模式
Added some wheels to a 20 gal air tank I have.  Added them to the legs, as far down as possible.  Keep the heat from the tank etc...Turned out some bad welds, but for the weight it will work for me.  Didn't get the paint off to well, and not near enough so it did not turn out well.  But the end product turned out to what I wanted.  Just not a good weld.Need to add legs and a handle on the other end now.  "before pic (second tank) and after"Wheels and axle free, cut the axle down, and put a cotter pin in one side.  Works, had the stuff to do so.  Better then 6" sticking out one side.The smoker did a lot better.  Could have done better on the welds, but not to bad for a hobby welder.Feel free to add any improvement.
GMT+8, 2025-12-30 02:23 , Processed in 0.093463 second(s), 18 queries .
