查看: 2|回复: 0
Stuck leads
发表于 2021-8-31 22:43:10 | 显示全部楼层 |阅读模式
On my dialarc 250 the ground clamp lead has the piece thatplugs into the welder and it has melted in there what can i do to get it out or switch the polaritysMiller Dialarc 250Miller Bobcat 225Hobart Oxy/FuelCouple of Dewalt and Milwaukee GrindersJET Bandsaw and Drill Press
Reply:Originally Posted by farmwelderOn my dialarc 250 the ground clamp lead has the piece thatplugs into the welder and it has melted in there what can i do to get it out or switch the polaritys
Reply:I'm rebuilding one right now, I'm going to replace the miller jack plugs with these..http://www.ebay.com/itm/Lenco-081061...item51ca99ae1bExpert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by 7A749I'm rebuilding one right now, I'm going to replace the miller jack plugs with these..http://www.ebay.com/itm/Lenco-081061...item51ca99ae1b
Reply:Originally Posted by M J DThat is the best way in my opinion, those miller plugs like on the dialarc or mm200 are a huge amount of suck. They loosen up with heavier use , overheat and then your in the same situation again.
Reply:Originally Posted by 7A749I just wish they made ones with a yellow body to match the originals..
Reply:Originally Posted by 7A749I just wish they made ones with a yellow body to match the originals..I got the ones I have as a gift, so I'll make due with them. Prolly use some fusion paint on the AC side.Of course, this Dialarc isn't gonna be very "stock" by the time I'm done with it anyways
Reply:Originally Posted by M J DI didn't know that they weren't available, I just might have some in the box of crap ,if so I will let you know.
Reply:Originally Posted by PipelinerDo you have a picture of an original?
Reply:Originally Posted by 7A749All the Lenco catalog has are red and black as far as I saw. If you find any let me know.
Reply:Originally Posted by M J DI looked at lenco and saw that as well. I had some parts for a mm200 and I think they are the same plug and machine receptacle. Its been a while but I think high and low range used the yellow plugs.
GMT+8, 2025-12-30 02:24 , Processed in 0.103352 second(s), 18 queries .
