Refurbish Acorn Platen?
发表于 2021-8-31 22:43:09 | 显示全部楼层 |阅读模式
What options are out there and companies that perform the work to refurbish a 5'X5' Acorn Platen that has seen a lot of service and more recently left out in the weather ?
Reply:Look for places that do surfacing/hardfacing.  They can do a build up and machine the surface flat again.
Reply:USE!  unless your very concerned with a perfect level surface then getting it Blanchard ground is what your going to want to get done.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Dualie, Supe, thanks for the replies.  Helped locate a nearby shop with reasonable price.
GMT+8, 2025-12-30 02:24 , Processed in 0.093340 second(s), 18 queries .
