Dual Flow Meters ???
发表于 2021-8-31 22:43:05 | 显示全部楼层 |阅读模式
Does anyone make a "T" fitting that allows you to connect 2 flow meters to the same bottle???
Reply:http://store.cyberweld.com/smduflre3...FU5xQgodlDoAvQ
Reply:Soory can't remember the part # but I bought a dual ball and tube regulator from Victor with one bottle nut to back purge. Basically 2 regulators teed off a single bottle nut wasn't cheap though but has treated me well.
Reply:I bought a HTP dual flow meter on ebay for like $100. cheap and it seems to work just fine.Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by jlameshttp://store.cyberweld.com/smduflre3...FU5xQgodlDoAvQ
Reply:Originally Posted by MikeGyverI bought a HTP dual flow meter on ebay for like $100. cheap and it seems to work just fine.
Reply:[quote=rahtreelimbs;2986351]Does anyone make a "T" fitting that allows you to connect 2 flow meters to the same bottle???[/quoteThis is what I have. http://weldingdirect.com/ccoteecgfori.htmlLast edited by Showdog75; 08-22-2013 at 09:36 PM.
Reply:I bought one on ebay for about 25 dollars I think. Been a while.
Reply:all you have to do is remove the existing flowmeter from the regulator (1/4" npt) ,install a tee in the regular output,purchase another flowmeter and install it on the branch of the tee. the regular has ample capacity to supply both the torch flow and the purge flow. adjust each individually to your preference. the brass 1/4" npt fittings can be purchased at plumbing supply houses or any home store.Last edited by dbl612; 08-25-2013 at 10:11 AM.
Reply:Originally Posted by dbl612all you have to do is remove the existing flowmeter from the regulator (1/4" npt) ,install a tee in the regular output,purchase another flowmeter and install it on the branch of the tee. the regular has ample capacity to supply both the torch flow and the purge flow. adjust each individually to your preference. the brass 1/4" npt fittings can be purchased at plumbing supply houses or any home store.
Reply:I don't get why everyone over thinks this so much.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by Showdog75I'd be cautious doing this because I don't think regular brass plumbing fittings are designed for high pressures that Hp cylinders typically see. I don't play with 2000+psi.
Reply:I bought a Smith dual outlet flow meter for less than $150. (Weldingsupply.com)part No. 33-50-580 (I think)I think the Victor ones are over $300. As best I can tell it doesn't leak so its hooked up all the time.  Flow just set to zero.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
GMT+8, 2025-12-30 02:24 , Processed in 0.092359 second(s), 18 queries .
