anyone here that builds rollcages?
发表于 2021-8-31 22:42:58 | 显示全部楼层 |阅读模式
anyone here build rollcage's for work or on the side? if so post up pics of past and current projects.If the conversation isn’t money, then I’ll see you later.
Reply:Was that "please"?Are you looking for anything in particular?  Design or construction advise?  Or just don't want to utilize the search tool?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:The one and only iv done haha
Reply:A few projects from a couple years back.A couple Rhino cages and a sand rail.Maybe ZT will post here. His roll cages and tube work are some of the nicest I've seen.Miller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:You've been on the forum longer than me and you don't know ZTFAB?  I'm just giving you crap, but this one's easy.
Reply:Well, actually I do know him. He's a friend. Been in his shop, and have seen his incredible work first hand.Miller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:Originally Posted by VenomWell, actually I do know him. He's a friend. Been in his shop, and have seen his incredible work first hand.
Reply:Spend a weekend at the track. Any track. Old buddy here. We built engines at the same time(late seventies)--different shops.He and I are on the same page. Great guy-old friend.We didn't - don't play.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:You could swing by Charlies too. Tell him Doug (Dr. Blammo me) sent you.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Like a dis?:-)Rzr cage I made last year or so for a guy Attached ImagesMiller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:Is there a question of comment the original poster had about building cages?Last edited by Venom; 11-15-2013 at 08:51 AM.Miller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:Originally Posted by BrownfauxOh not you. The original poster.  If I want to see roll cages I would just start by looking up ZTs posts. But I am jealous that you've been in the presence of greatness. Sent from my iPhone using Tapatalk
Reply:all my stuff is on polaroids, done them before I had digital media capabilities, and not certain I still have those... Go to pretty much any chassis builder, most of them will gladly show you their shop and work, just be courteous and ask...  If you have any 1/4 mile tracks near you that would be a good place to start,  if you see any of the 10.5" tire street car shootouts ,check out their cages, they can have some pretty elaborate work done on their cages..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:yea that stuff looks good, anything for drag cars or circle track cars? looking at practicing over the winter maybe get a job in a shop doing this.If the conversation isn’t money, then I’ll see you later.
Reply:I did these recently....
Reply:I'm interested in this one. I trying to bend some tubing with my model 3. One bend or two not to bad but more than that is difficult.Sent from my Nexus 7 using Tapatalk 4Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Originally Posted by SteelwillI'm interested in this one. I trying to bend some tubing with my model 3. One bend or two not to bad but more than that is difficult.
Reply:Originally Posted by brucerAre you getting tired?      Use some white lithium grease, I used the spray the tube prior to bending it, helps knock the friction down..  other than that you have to man up, or convert to hydraulics. I also used a 8" piece of 1x2 tubing welded to a piece of 36" round tubing for an extension, made it pretty easy to bend manually...
Reply:Do yourself a HUGE favor, and invest a couple hundred dollars in Bend-Tech.Design your cage, and it tells you where to bend, and at what angles. Do a youtube search on it.Its a an amazing and fairly simple program!Miller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:When I first got my bender I did several test bends at different angles and noted the memory of the material..  I always used dom tubing and I always used the same supplier. get a degree ring..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:My modei 3 has that already. I'm attempting to recreate an old school mini bike frame the first two bends are easy, the third one is giving me trouble because it bends up and inwards. The problem I'm having is positioning the tube in the bender correctly to obtain this bend.Last edited by Steelwill; 11-16-2013 at 05:42 AM.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Originally Posted by SteelwillMy modei 3 has that already. I'm attempting to recreate an old school mini bike frame the first two bends are easy, the third one is giving me trouble because it bends up and inwards. The problem I'm having is positioning the tube in the bender correctly to obtain this bend.
Reply:u guys miggin or tiggin, i see some people mig and some tig. i prefer tig esp when it comes to one off stuff.If the conversation isn’t money, then I’ll see you later.
Reply:I usually mig welded because it was much faster, time was money then...tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:I usually leave the decision to mig or tig up to the customer or if the sanctioning body they are racing under requires one or the other. As a general rule most everything can be mig'd except 4130. With NHRA rollcages Ive had to cut holes in the floor to drop the cage low enough to do a complete 360 weld. If not you have to gusset. Bend tech software really helps or you'll beat yourself up in time, waste and frustration. I have also had customers bring me a a bolt in cage and they say go ahead and weld it... problem is there are twice as many welds to make because all the connections have a sleeve with two ends. I only do cages if things are slow because they aren't very good money makers. I sweat every inch of it as if it had to protect me. You can buy a custom bent frame and then customize it to the customer's liking. I buy Art Morrison cages then tune them to my liking. You also have to consider the insurance end of it. A lawsuit will likely follow if there is a fatal accident or major injury. After you try a few you 'll probably agree they are fun and challenging to do but not worth the money or liability. Just my thoughts...Here's a few of minehttp://all-a-cart.comWelding Cart Kits and accessories
Reply:http://all-a-cart.comWelding Cart Kits and accessories
Reply:Originally Posted by ZTFab
Reply:Originally Posted by copeIf you keep practicing long enough, you will be pretty good.
Reply:Originally Posted by ZTFabI learned it all from youtube
Reply:Well I was gonna post some to show how its done but I think ZTFab has got it covered!
Reply:Originally Posted by MinnesotaDaveProbably from "mig like tig"
Reply:Originally Posted by ZTFabNo way, it's too cold. It'll never work.
Reply:Attached ImagesLast edited by jmink427; 11-19-2013 at 03:20 PM.
Reply:Originally Posted by jmink427
Reply:thats some very nice welding there.If the conversation isn’t money, then I’ll see you later.
Reply:Originally Posted by brucernice impala, what kind of engine and turbo setup does sit have?
Reply:I saw this tonight on the news and thought it was worth sharing. When you ask about roll cages, if it were me, I'd want the guy who built this one to build mine. The whole, great story, is here. He's back home and recovering well.http://www.hondatuningmagazine.com/f...insight_crash/
Reply:This is about as bad as it gets......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Here's what it looks like from the inside of an 800hp Trophy Truck doing 105mph. ***LANGUAGE WARNING***http://all-a-cart.comWelding Cart Kits and accessories
Reply:Here is the same truck to give you an idea of what it looks like from the outsidehttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Anyone know how they made out, especially the navigator. That was pretty darned bad.
Reply:Originally Posted by jlamesAnyone know how they made out, especially the navigator. That was pretty darned bad.
Reply:worst wrecks i've seen were in sprint cars.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
GMT+8, 2025-12-30 03:53 , Processed in 0.075134 second(s), 18 queries .
