Hobart 6010
发表于 2021-8-31 22:42:56 | 显示全部楼层 |阅读模式
Anyone know where i can get 5 or 10 lbs of Hobart E6010. I think its called pipemaster or something like thatMiller Dialarc 250Miller Bobcat 225Hobart Oxy/FuelCouple of Dewalt and Milwaukee GrindersJET Bandsaw and Drill Press
Reply:Why? It's nothing to write home about!  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:hes right.  A few years ago, the welding dept bought a bunch of 50lb boxes of hobart 6010.   i dont know if it was pipemaster, or what its name was, but the stuff was horrible.    Honestly, i suspect it was a bad lot, because noone would ever buy it a second time.    You'd actually get like arc blow, where you couldn't direct your weld.   You could actually see the flux break off  prematurely in flakes, because of the heat right above the end of rod while your welding.    It was so bad, it wasn't even good enough for the beginner students to learn on.    The teacher then, started sticking it in lincoln cans, to try to trick some of the students into using it.   I don't think that worked very good, not sure how he disposed of what was left.
Reply:5p+ is all a man needs when it comes to 6010....Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
GMT+8, 2025-12-30 03:44 , Processed in 0.109410 second(s), 18 queries .
