Found this lincoln red d arc?
发表于 2021-8-31 22:42:55 | 显示全部楼层 |阅读模式
Does anybody know why the Machine runs but their is no power to the leads? Owner states. What may typically be wrong, guy has it for sale locally and I don't know much about these gensets, don't have the model number. Would it be a horror story making this a project? Thanks Sent from my SGH-I747M using Tapatalk
Reply:I'm using that exact machine at work right now. It's a dumbed down Lincoln 300. It probably has a Kubota diesel in it. These are a very nice welder. Very smooth soft buttery arc. How many hours are on it? Does it make power on the 120v receptacles?Last edited by snoeproe; 02-13-2015 at 07:39 AM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:How long has the owner had it? Has he used it much? If the owner recently bought it and is now selling it without using it, I have an idea for you of something to check.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Might just need to be flashed. They are a good machine though. I don't think they have any throttle control at all. Just one speed all the time. The Kubota is a long life reliable engine.
Reply:I'd start off checking the most common thing that folks don't know about these welders and what causes them to not strike an arc. The remote amp control plug in. This machine is a plain Jane lincoln. Nothing on it for features at all. No fuel gage, constant 1800 rpm running diesel. No remote control on/off switch. Open the left side cover and you will see where the leads plug into the machine. To the left of that is the remote amp control pig tail/plug in. It should be a twist lock style plug. To use a remote amp control you simply plug in a cord and attach your control box. However, if your not using a remote and your using the panel on the machine for amp control, you must plug the short pig tail into the remote amp control plug in. If the pig tail is hanging there and not plugged in, the machine will not strike an arc, period.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Thanks for replies guys, guy as it for sale in city, don't think it is much have not been able to find one for cheap, what are they worth? Not Functioning, snoeproe, thanks for info will get back to you when I check machine. Sent from my SGH-I747M using Tapatalk
Reply:The exterior looks a bit rough. Interesting to see how many hours are on it.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-30 03:46 , Processed in 0.222588 second(s), 18 queries .
