Insulating From heat
发表于 2021-8-31 22:42:55 | 显示全部楼层 |阅读模式
I have added a bracket on my engine-driven welder to mount an electric fuel pump.It is fairly close to one of the exhaust pipes, so I want to insulate it from the heat.I will install an aluminum heat shield first (or maybe a flux-core hand shield), but would like to know if there is a form of thin sheet insulation that would supplement the heat shield.I would like it to separate the fuel pump from the bracket.I don't really know if it is necessary, as the original fuel lines ran right through this area with no protection, but I'd feel better if I could do it.ThanksHobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:they sell exhaust wrap , for headers in performance cars, you could either wrap the exhaust or use it on the heat shield..any performance auto place online would have it..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Hah!the first line of your signature sure applies to me!Thanks.Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:if I dont write things down now, ill forget when I leave the room to go get what it was that I wanted..lmao..............Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:If you install a heat shield similar to the way the heat shield on a catalytic converter is... you should have no problem ...the air space is all the insulation you need.Measure with a micrometre, mark with chalk,  cut with a torch.Never force anything...just get a bigger hammer.RoyOld Airco buzz box approx 1974Lincoln mig pack 15Lincoln 175 square wave1954 9" south bend lathe
Reply:Originally Posted by roadkillbobbif I dont write things down now, ill forget when I leave the room to go get what it was that I wanted..lmao..............
Reply:Originally Posted by olcarguyIf you install a heat shield similar to the way the heat shield on a catalytic converter is... you should have no problem ...the air space is all the insulation you need.
Reply:Kinda what I had in mind too.You know the mind is going when you find yourself in the middle of the stairway, and Don't remember if you were on your way up or down!Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:you can do the cat shield like mentioned, and put something like this on fule line http://www.ebay.com/itm/4-PC-TITANIU...681666&vxp=mtr
GMT+8, 2025-12-30 03:44 , Processed in 0.108280 second(s), 18 queries .
