Name of templates/guides for notching drill pipe??
发表于 2021-8-31 22:42:53 | 显示全部楼层 |阅读模式
I cannot remember the manufacturer or the generic term for the items that come three (3) (I think) to a set for notching the end of drill pipe with a O/A torch or plasma cutter.  Seems like there are two halves with springs that allow you to slide it over the pipe and cut it as in building a fence.   Thanks for anyone with better recall than me!
Reply:Pipe cutting template or guide will usually work.Like this:http://www.tractorsupply.com/welding...ipe-od-3821219  The best laid schemes ... Gang oft agley ...
Reply:That's what I was looking for. Thanks MoonRise
GMT+8, 2025-12-30 03:53 , Processed in 0.211603 second(s), 18 queries .
