Where to find drill bit?
发表于 2021-8-31 22:42:53 | 显示全部楼层 |阅读模式
Need to drill some 1 inch holes, cant afford an annular cutter, will be drilling thru 1 inch steel. Any suggestions on bits? Only need a couple dozen holes over time. Thnx
Reply:Mc Master-Carr, Msc, Enco, Lowes, Home depot, or any good hardware store.Tough as nails and damn near as smart
Reply:Slow rpms, and preferably done in a drill press or with a mag drill. You need to keep an even pressure on the bit to keep it cutting. Hand held drills can take you for a ride and be quite dangerous if the bit grabs as it breaks thru..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Think I misstated, was wondering what type(and where) of drill bit ie will a hole saw work, or do I need to buy a 1 in bit? But the ideas on where to look for them is a help, I live in nowheresville! Will be using my big drill press as slow as I can get it, need to drill some 1 in steel for a log splitter> THnx~!!!
Reply:I've used both hole saws and standard bits. I'd use a standard drill bit given a choice. They seem to hold up better than holesaws in the long run..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWI've used both hole saws and standard bits. I'd use a standard drill bit given a choice. They seem to hold up better than holesaws in the long run.
Reply:LOTS of cutting oil added at regular intervals using regular pointed drill bits.  Drill small pilot holes and then graduate upward with larger and larger bits until the largest hole is achieved.  Drill slowly with considerable force.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:With regular drill bits, I would drill that in at least 4 graduating steps.   As much money as you'll spend on drill bits and drilling time, it may be more economical to go ahead and buy the annular cutter instead.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:How thick of steel is it your drill through. If its not that thick you can go with a hole saw.Type of bit depends on your drilling device? What are you going to use a hand drill? Drill press? Mag base? Theres too many variables.
Reply:I've cut hundreds of 1" holes through 3/4 steel using hole saws. Quick and easy.   Usually get 30-40 holes cut before the saw needs replacement.
Reply:A regular 1" twist drill should work fine.  Bi-metal hole saw would be my second choice.With a twist drill, don't try to do this in several steps.  Just two steps is ideal.First, drill a hole the size of the web of the larger bit (with a 1" bit, that's in the neighborhood of 5/16").  Then drill it full size.  If you drill much larger than the web, the large bit will chatter and wobble,
Reply:....I second the motion of the post before mine....I've drilled thousands of holes in plate up to 4" thick...with 1" or larger drill bits...  Holesaws...30-40 holes per saw....kinda' pricey when you pay $15-20+ for one holesaw (that you can't even sharpen)....buy a good drill bit with 1/2" shank...I like Precision Twist Drill...they are available from machinery tool stores...around $30-35 for a 1" unit....then drill the smaller pilot...run the bigger drill couple hundred rpm....keep it oiled...the plain black oxide drills last quite well...  I've gotten 50-100 or more holes out of a drill like this before needing the sharpening....drilled a whole lot of plate and wide flange I beams like this....  If you don't have big enough drill press...you can probably rent a mag base unit...really saves the time and energy....and with the mag-base you can use the annular type cutter, but they're pretty expensive...very fast though, as you're only removing a small percentage of the material from the plate...compared to a drilling operation.Dougspair
Reply:Originally Posted by DougAustinTXLOTS of cutting oil added at regular intervals using regular pointed drill bits.  Drill small pilot holes and then graduate upward with larger and larger bits until the largest hole is achieved.  Drill slowly with considerable force.
Reply:Cool, thanks all for the info, been years since I did this stuff(30plus)! Will look for the 1 inch bit and use lots of oil! Will do the 2 step routine too!!! Thnx for starting me the right way!
Reply:Originally Posted by tnhomestead. . .Will look for the 1 inch bit and use lots of oil!. . .
Reply:Drill chatter will be your biggest enemy and drill grabbing your work piece a close second if you don' clamp your work down tight. Pilot holes and slow speed with steady pressure as others have suggested should get er done.Loncoln tombstone 225 ac/dcEutectic O/ADaihen corp. OTC 270 XSR mig with Tregaskiss gunMiller bobcat 225I say watch the welder and my black lab says watch it yourself my eyes are killing me.
Reply:Step drilling works fine with old style drill bits with more than 2 flutes.  Yeah, you used to be able to buy these.Step drill with a 2 flute bit, and the torque at the end of the drilling cycle(hole punch thru) will tear the bit out of the chuck, or tear the electric drill out of yur hands.  Or tear up the ends of the bit.Pilot hole the size of the "dead" portion of the bit, and press hard, and be patient.Step drilling can be very grabby."Any day above ground is a good day"http://www.farmersamm.com/
Reply:I didn't know what an annular cutter was and was curious so I looked on Ebay. Seems to be pretty reasonably priced when compared to regular drill bits that size. If they'll fit your drill press that is. _
Reply:I didn't know what an annular cutter was and was curious so I looked on Ebay. Seems pretty reasonable when compared to regular drill bits that size. If it will fit your drill press that is.http://cgi.ebay.com/CYCLONE-PREMIUM-...item5636a64cd7
Reply:Annular cutters be the bomb.  Fairly reasonable from some sellers on Ebay,, but bear in mind that you also have to buy a holder for the cutter that will fit your drill press (Morse taper), or your mill(R8).  good one can cost almost 80 dollars"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Denrep brought up a very good point, in his short hand sorta wayWater can be a very good coolant, and a lubricant to some degree.  Only trouble with water is the rust factor.  Not a problem in hand held tools, but a problem in mills, and presses.If you see steam coming off of the water/oil (well, smoke if it's oil), your coolant is doing what it is supposed to do.  Dissipate heat.  Heat is the enemy of your cutting surface."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Wonder if I can get an adapter to run those in a regular drillpress,have a mt3 spindle I believe(can handle a 5/8 shaft), prices are a lot better than other ones I saw!  THanks for that info!
Reply:Originally Posted by tnhomesteadWonder if I can get an adapter to run those in a regular drillpress,have a mt3 spindle I believe(can handle a 5/8 shaft), prices are a lot better than other ones I saw!  THanks for that info!
Reply:www.travers.comProduct        Description        Price Each  26-035-555   10816 #3MT X 2-3/8 HOLE W/O COOL'T INDCR HOUGEN  88.60 EA    26-035-551  10806 #3MT X 2-3/8 HOLE W/ COOL'T INDUCER HOUGEN 166.87Pricey, especially with the coolant adapter. The 2-3/8" dimension is the maximum recommended hole diameter.Lincoln SA200, HH135, Lencospot, HF80 Inverter, Rockwell 11x35 lathe, HF drill mill, Kama 554 tractor w/ FEL & BH, Belarus 250AS, lot's of Chinese tools
Reply:Forget all the fancy crap.  You don't need special coolant thingys.Use flood coolant, and take the dam thing outta the hole once in a while to let the coolant cool the teeth, and fill the hole boreCalled the pecking method.  Drill, pull it out, let it cool off with the coolant washing over it, the reinsert in the hole bore.  Do this in short cycles, and the tool will last for a very long time"Any day above ground is a good day"http://www.farmersamm.com/Check out Victor Machinery Exchange...  Prices are very reasonable and quick shipping. They have your, reduced shank drills, hole saws, step cutters, and Annular cutters.    http://www.victornet.com/
GMT+8, 2025-12-30 03:44 , Processed in 0.103164 second(s), 18 queries .
