Trailblazer 325 arc reach question
发表于 2021-8-31 15:02:06 | 显示全部楼层 |阅读模式
Like the title says, I have an issue with my trailblazer 325. When using the extreme 12vs arc reach feeder, which isn't often, I believe it used to stay at idle until you strike an arc then it idled down while welding. Had to get a new board in the feeder and now the tb325 runs at high rpm and only kicks down once welding. Does that seem right? Like I said, i dont use the feeder often, maybe a few times a year to weld 18g door jambs together.
Reply:Had a chance to mess with the machine today. Found out it was my mg remote base being hooked up causing the rpms to remain high. Glad that's all it was.
GMT+8, 2025-12-18 18:21 , Processed in 0.113259 second(s), 18 queries .
