hypertherm 190c plasma for sale
发表于 2021-8-31 22:42:44 | 显示全部楼层 |阅读模式
hypertherm 190c for sale about two and half years old  $700 used about ten timesPortable Air Plasma Cutting System With Built-in CompressorThe benefits of Hypertherm technology:Integrated compressor - no air supply needed Convenience of 120 V input 1.32 kW cutting power exceeds most competitors Portable, professional package Built-in storage compartment for consumables Recommended Capacity: mild steel* to 1/8 inch (3 mm) at cutting speeds over 20 inches (500 mm) per minute. Maximum Capacity: mild steel  to 3/16 inch (4.5 mm) thick at cutting speeds. Severance Capacity: mild steel  to 1/4 inch (6 mm) at slow speed.* Non-ferrous metals typically require a 10-20% capacity reduction.*A 20-amp circuit for 120-volt operation is recommended.Advanced Power SupplySuperior power supply design delivers proven Hypertherm performance in a compact, truly portable package. 1.32 kW delivers superior cutting power from a 120 V outlet for the sheet metalprofessional. Built-in air compressor provides required gas. Boosted open-circuit voltage rating can accommodate low-line conditions of -20% typical on work sites or when utilizingextension cords. Advanced electronic architecture provides constant current control for consistent quality on varying power levels. A chopper power supply provides superior energy efficiency over competitive droopers. Hypertherm's patented pilot-arc control circuit facilitates uninterrupted cutting on expanded metal or gratingwhile minimizing torch consumable wear. Over- and under-voltage sensing circuits protect the machine from damage and permit motor-generator operation(on 2.5 kVA auxiliary circuits).Intelligent Torch DesignHypertherm's new patented PAC105 torch design delivers maximum performance in a rugged, ergonomic handle.Intelligent torch features promote cut accuracy and speed, while enhancing productivity and life. Higher Speed and Capacity.Total cutting power is a product of output current (amps) and output voltage. The PAC105 torch is designed to generate a boosted output voltage - rated at 110 volts - producing up to 45% more total cutting power than typical competitors with the same output current. Longer Consumable Life.HyLifeª electrodes last longer than ordinary designs (300% longer, in some tests) by using the same hafnium-sizing technologies developed for Hypertherm's advanced mechanized systems. Easier Operation.An optional patented nozzle shield (shown below) provides additional nozzle protection and allows superior, no-stick drag cutting and template following.No Interference.A patented "blow-back" torch design provides a strong pilot arc for penetrating rust, paint and other coatings without the high-frequency interference that can damage sensitive electronics  (PCs, phone systems, machine controllers, automobile microchips).Rugged Operation.No breakable ceramics threaten the life of the torch. The durable, high-impact clamshell handle provides years of reliable service. Cooler OperationA standard post-flow feature provides torch cooling after the cut for longer torch life and easier consumable handling. An interrupt feature automatically stops the post-flow on re-trigger for rapid re-fire. Safe Starting.Hypertherm's patented safety trigger protects against accidental starts. Ready Access to Consumables.A built-in parts compartment keeps consumables close at hand. Attached Images
GMT+8, 2025-12-30 04:25 , Processed in 0.100771 second(s), 18 queries .
