Opinions on this fix
发表于 2021-8-31 22:42:41 | 显示全部楼层 |阅读模式
just wondering what some of you guys thoughts are on fixing this crack. its for a piece of tillage equipment on the farm. im thinking it will need more than tighten the gap up and weld. I was thinking possibly a piece of angle iron underneath with a notch cut out allowing it to fit around the round tube axle. what do some of you guys think? that crack wraps up around part of the opposite side too this is a view from the top, the crack is on the bottom more soR.T. Welding LLCOn Site ServiceColumbus, NJ
Reply:Pulled together, vee'd or cut for a full penetration weld. Then the best thing that can be done is to plate the end of the tube. That adds a lot to a assembly like this.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:good idea, I shoulda thought about that one!R.T. Welding LLCOn Site ServiceColumbus, NJ
Reply:The round is it tube or solid shaft?  Angle iron would help. As posted earlier vee and weld. But be careful we had one similar and tube cracked and separated from rectangle tube.You could pull the wheel hub & keeper bolt hole saw a hole in a piece of 3/8 or so plate and weld to the side after repairing the crack. Could also put a small gusset on back side. Just depends on how much work you want to do. Good luck
Reply:yeah ill have to see what diameter that tube is and get a hole saw to match up/capable of drilling through something heavier like 3/8R.T. Welding LLCOn Site ServiceColumbus, NJ
Reply:I did what weldone stated about hole saw in plate and the cap end of tube on a neighbors digger years ago. Worked well. I did the other wheel too .
Reply:I like the tip. Thanks to post it here.. I agree with the suggestion and will follow this...OpeningTimesUK
Reply:Just curious...but can the axle be moved a couple inches further down the tube into "fresh meat" without causing any functional issues? Of course, you'de have to do both..and cap as mentioned.Last edited by SMC Weldcraft; 11-29-2013 at 06:18 AM.POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:I have fixed several wheels for farmers over the years and this is what I did and so for never had to repair them again. If you have time, remove (first pic, look to the left and you will see the bolt) the bolt going through the axle.  You will probably have to heat the shaft to remove it. After you remove the wheel and shaft, repair the crack, then cut a plate and reinforce the 2"X 4" tubing.
Reply:I think im going to do that. cut a hole in a plate, slide it over tube weld it, then weld a plate on the back. this is after grinding out crack and welding first of courseR.T. Welding LLCOn Site ServiceColumbus, NJ
GMT+8, 2025-12-30 04:22 , Processed in 0.103355 second(s), 18 queries .
