Allen key third hand
发表于 2021-8-31 22:42:41 | 显示全部楼层 |阅读模式
Hi,just starting to weld and as one of my first projects ,i put together a third hand,trying to get the hand on my cheap tig welder so sorry about the welds...Just used 3 old allen keys ,the weight was part of an old machine and the copper tip... Attached Images
Reply:Looks perfect to me!Hobart 125 EZHobart Handler 140Everlast STH 160Generic 210 Amp Welder/GeneratorHobart Air Force 500i plasma cutterChinese 50 amp plasma cutter! Youtube Channel : Henrymac100
Reply:Hey pretty cool! I would prefer to taper the copper to a point tho for the thin stuff. If you had to use a slight angle the flat would probably slide right off. Looks good tho, and I hope you didn't waste good allen keys.  I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Great idea!  And I have a bunch of unused allen keys!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Awesome idea!  Sorry I have a question. What's the reason for the copper tips on third hands?
Reply:to provide a better ground- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Originally Posted by weldermikeHey pretty cool! I would prefer to taper the copper to a point tho for the thin stuff. If you had to use a slight angle the flat would probably slide right off. Looks good tho, and I hope you didn't waste good allen keys.
Reply:This may seem like a dumb question... what is it for?JobSmart MIG125Lincoln AC225-SLincoln Pro-Mig 175Dewalt GrindersRidgid ChopsawIR Garage Mate CompressorAny thing worth doing, is worth doing right.
Reply:Originally Posted by UKfanThis may seem like a dumb question... what is it for?
Reply:Well I guess you don't know till you ask. thanks.   the way I work I need a third and fourth handJobSmart MIG125Lincoln AC225-SLincoln Pro-Mig 175Dewalt GrindersRidgid ChopsawIR Garage Mate CompressorAny thing worth doing, is worth doing right.
Reply:Southern, nice job!  I like that idea to use those Allen keys for small projects and a delicate touch.  For larger projects, I made this "third finger" out of rebar,  a long time ago.....Then I welded a square piece of 1/4" plate on top to add as a weight platform.  There have been times when I needed a third finger with some force on a heavy piece of steel, until I could get it tac'd up.   This 1/4" piece was hit quickly with several stringers of 7014.  This last picture just shows a quick example of using some heavier piece or pieces of scrap metal as added weight, when necessary.   I finally electroplated the third finger with zinc, just to keep the rust off of it.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Here's another thread that was posted. Mine is post # 7.   http://weldingweb.com/vbb/showthread.php...=weld%20finger
Reply:Cheaters....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:looks good.  I like the Allen key idea, too.  And I have a bunch of bad ones that could be donated for this.Thanks for posting
Reply:Originally Posted by BD1Here's another thread that was posted. Mine is post # 7.   http://weldingweb.com/vbb/showthread.php...=weld%20finger
GMT+8, 2025-12-30 04:25 , Processed in 0.100321 second(s), 18 queries .
