shop ventilation
发表于 2021-8-31 22:42:40 | 显示全部楼层 |阅读模式
there are lots of germs floating around where i work so proper shop ventilation is a must. i have at least 4 24 inch pedestal fans going at all times but the large bases take up lots of valuable floor space. this universal fan mount can be adjusted in almost any direction and moved out of the way if needed and also makes it harder for anyone to "borrow". Attached Imagesi.u.o.e. # 15queens, ny and sunny fla
Reply:Nice, but I'm not sure how that helps with the germs. I'd think some sort of fresh air in, exhaust air out system would be a better option, though I can understand where you work cutting holes in walls and roofs might be frowned upon by the powers that be. Maybe some sort of electrostatic filters might be an option..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I just open a window this time of year. It's clocking about 50 mph right now. It'll let up in March. See why I like stick ? Attached ImagesBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by DSWNice, but I'm not sure how that helps with the germs. I'd think some sort of fresh air in, exhaust air out system would be a better option, though I can understand where you work cutting holes in walls and roofs might be frowned upon by the powers that be. Maybe some sort of electrostatic filters might be an option.
Reply:Originally Posted by BurpeeI just open a window this time of year. It's clocking about 50 mph right now. It'll let up in March. See why I like stick ?
GMT+8, 2025-12-30 04:24 , Processed in 0.213924 second(s), 18 queries .
