My children wanted to keep a large wolf spider, or maybe it is a trapdoor spider, as a pet.I dug an old 20 gallon aquarium out of the storage building and quickly fabricated a lid for it.I had a very hard time with the hardware cloth. With the amps too high it quickly burned through. With the amps low enough to not vaporize the hardware cloth, it would not heat up the 0.25 in flat stock enough to stick good.It really looks crappy, but here are the pictures of the underside.Should I have used gorilla glue instead?
Reply:Gorilla glue may have worked. Looks like it will do its intended job.As for me it would have been held captive with a size 11 Redwing. HAHA
Reply:you can grind it down some. I think that you would have had better luck using thinner material for the frame.
Reply:just don't teach the spider to use a cutting torch and you will ok
Reply:The spider is the only one going to be looking at that side anyway. Wait till that spider has about a gillion babies. Mrs. Major is goona be looking for someone to choke.
Reply:When I weld a thin screen to a frame, I make another frame from flat stock to sandwich the screen between, clamp the frames together and tack weld the frames.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I think desertrider has the right idea. You could drill some holes in the strips and plug weld it. It would make the spider really love you and that is what it would take before I would get my hand near that ugly varmit. What do you feed that thing anyway ?
Reply:PS the cage looks good and I don't think the spider can break out of that one. I bet you had to build a good one like that before your wife would let you bring it in the house - Right
Reply:big worm ---it would have made to big of a mess if I had stepped on it.Mark --- I believe you are right about the frame needing to be much thinner stock.prop-doctor --- I keep my cutting torch locked up, kids are showing too much interest right now.Sandy --- You're right, It looks ok from the top and the spider has not complained yet.DesertRider33 --- If I had had some thinner stock I thought about the sandwich method, but the 0.25 in stuff was all I had laying around.6010 --- If the kids are able to tear up the first one I made then that is what I will do for the next one. The kids have been catching crickets and putting them in the cage. The next morning we have to clean out the dead crickets. Oh, It's not in the house. It's on the back porch.
Reply:That is an awesome creature. Bodes well for your environment that it lives near you. Less obnoxious bugs and no pollution. What part of the country?Airco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:sunline, not only do they live near me, this one was found inside my house. My wife went downstairs to the storeroom where we have an extra refrigerator to bring up some bottled water, a few minutes later I heard her calling my name loudly. This spider was standing in the middle of the doorway of the storage room and my wife was on top of our chest freezer. We live in rural central Mississippi.
Reply:I believe the Chinese consider spiders to be good fortune omens. I have many in my basement as well but non that large. The only ones we have around here that are harmful are the brown recluse which one does not want in ones shoes....Airco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:I think your wife had the right idea. I don't like spiders, at all.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:did you not think of cold welding ?? as in JB Weld etc?? I use it for a lot of different things and find it very handy for odd projects like this,, of course as an experiment in welding I would say your attempt was quite interesting!!
Reply:Originally Posted by fuzzykjundid you not think of cold welding ?? as in JB Weld etc?? I use it for a lot of different things and find it very handy for odd projects like this,, of course as an experiment in welding I would say your attempt was quite interesting!!
Reply:Spiders are creepy. They are fun to watch though. I just tacked some hardware cloth to my stove as a spark arrester. I used a hot enough setting to melt into the base metal. I held the gun just far away from the wire cloth to not vaporize it and let the puddle melt into the wire. It's still difficult though.
Reply:General note: Original part of the thread was from back in early 2008..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Lay the screen down on the metal frame. Lay a washer over the screen (standard flat washer). Now weld the washer to the metal frame.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:Originally Posted by DesertRider33When I weld a thin screen to a frame, I make another frame from flat stock to sandwich the screen between, clamp the frames together and tack weld the frames.
Reply:Originally Posted by con_fuse9Lay the screen down on the metal frame. Lay a washer over the screen (standard flat washer). Now weld the washer to the metal frame. |
