lincoln plasma
发表于 2021-8-31 22:42:32 | 显示全部楼层 |阅读模式
The guys have been using our new plasma cutter and I got a chance to use it last week end a little. I noticed it would not cut very well. Could this be because the the "consumables"  are about gone? I have not really sat down to read the manual which was copied and pretty hard to read.Mark
Reply:i like lincoln welders but i thinkmiller is better and i never seen a lincolnplasma cutter in all the shops ive work in
Reply:Yes you may have to replace your consumables and / or adjust your air
Reply:It looks like it got used more than I thought. Working well now. Thanks
GMT+8, 2025-12-30 04:25 , Processed in 0.093754 second(s), 18 queries .
