I to cut a 5/16 slot in steel pipe about 10" down the length. I have a Drill press with a compound slid table. any one have any thoughts
Reply:Yeah, drill two holes and connect them with a cut off wheel.My name's not Jim....
Reply:if the table is functional i would use a 5/16 end mill and leave the cutoff wheel in my toolbox
Reply:I've got a compound table in my drill press too, but it's still a drill press. Milling ain't worth a chit.My name's not Jim....
Reply:i say drill the holes and use cutoff wheel in small angle grinderidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:I would use the plasma cutter myself with a guide.Lincoln 225 Tombstone,Miller Big 20,Hobart 180,150' Argon,A/D hobart hood 22 Ton Log splitter,79 F350 dump eats 4.75 TONS and still turns cutters,grinders,And a Hypertherm POWERMAX 30
Reply:i you use a drillpress for a mill it won't be very long before the chuck comes loose from the taper and get throw across the shop.Tough as nails and damn near as smart
Reply:I know it sounds good, but never use a drill press for millingDrill press has a Morse Taper arbor meant for vertical pressure, not axial pressure. SAme with the bearings in the head.The cross slide table is just for convenience in aligning drilling points, not for machining."Any day above ground is a good day"http://www.farmersamm.com/
Reply:I picked up a old mill from a friend ill get it set up this week.
Reply:sorry i incorrectly assumed you had a drill/mill
Reply:Since you have a cross slide table on the drill press, you should chain drill the slot.If you want a 5/16th slot, start with a 1/4" drill bit and drill a chain of holes that are just shy of touching each other. Once you have the chain of holes done, use a grinder to knock out the small webs between the holes and finish to your desired size.Unless your drill press has a drawbar, forget about trying to mill the slot......it's too dangerous.RexLast edited by rode2rouen; 11-21-2009 at 09:46 AM.Reason: speelage
Reply:never seen a drill press with a drawbar, I thought only R8 tooling, and other style milling arbors have a provision for use with a drawbar. Maybe some heavy duty presses might use mill arbors, dunno"Any day above ground is a good day"http://www.farmersamm.com/
Reply:whoa... a simple post and so many responses and links. My apologies for not doing the search first, that was stupid of me. Thanks for all the pointers, though!Taux simulation de prets immo bancaire | Credit simulateur de pret personnel | Simulateur de pret immobilier gratuit
Reply:Originally Posted by happernedwhoa... a simple post and so many responses and links. My apologies for not doing the search first, that was stupid of me. Thanks for all the pointers, though! |
