Can't find these clamps
发表于 2021-8-31 22:42:30 | 显示全部楼层 |阅读模式
I was on the miller forum and saw these brackets that you hold you work with. They had a link but I can't find them. Anyone seen these before? Attached Images
Reply:I haven't seen these exact assembly brackets, but my LWS has some nice EXPENSIVE ones ($50+) that have the clamps built into the bracket.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:I think I saw some at menards the other day called frame clamps.  Don't remember the brand.  What part of the state you in Drich?My name's not Jim....
Reply:I live in eastern Iowa. They said that they were a walker brand. I've looked all over for them.
Reply:just frabricate one that is balanced and u get a frame angle vice free... why buy when u can built?Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:What supplier do you use, DougAustinTx.?
Reply:Originally Posted by BobWhat supplier do you use, DougAustinTx.?
Reply:Guess on my part ... I think these are the clamps.I remember seeing them somewhere else on either this site or the Miller site along with a reference to the supplier - RAM - but I do not recall them being a StrongHand product but them being from some other manufacturer.StrongHand, Bessey, and others make the "similar but have the clamp built in" clamps.
Reply:Ram Welding Supplyhttps://secure.ramweldingsupply.com/...ew.mcic?s=1996"WELDER'S CORNER HELPER"I could have the legs tacked and square by the time you attach these clampsEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:It seems like buying something like the Strong Hands would be alot easier than those in the OP's pics.actually, those aren't even clamps.  They look like an aid for achieving a 90 degree corner.  You still have to use addtional clamps to hold those to the workpiece.
Reply:Originally Posted by Broccoli1Ram Welding Supplyhttps://secure.ramweldingsupply.com/...ew.mcic?s=1996"WELDER'S CORNER HELPER"I could have the legs tacked and square by the time you attach these clamps
Reply:Ram Welding has them.  www.ramwelding.com
Reply:I saw this yesterdayAnd I suppose I have to weigh in on itThe best thing to do is to use a good piece of straight square tubing to align parts.  Flat can have irregularities in it.  The only other tool you need is a good square (carpenters square)Clamp it up, check to see if it's square, look for gaps in the fitup, tack on the side that doesn't have a gap, check it with the square, then hammer it square to fit the square, and tack the side with the gap(you can use a screwdriver blade to resist shrinkage from the tack by inserting it into the gap as a wedge).  Sometimes the side with the gap should be tacked shy of square so it pulls into square after the tack shrinks.Don't go out and spend good money on all that crap the people want to sell you.  Learn how to anticipate the shrinkage, and control it.BTW.........................After you get done doin' all this fancified squaring.........the doggone thing will pull out of square the minute you do the finish weldsIf you don't want to deal with distortion............become a woodworker"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammIf you don't want to deal with distortion............become a woodworker
Reply:hi, BESSEY has something similar but not sure if they will hold verticle pieces. I have the bessey 7" and (" for corners and they are awesome but price is too! got mine at Amazon .com on a special sale that had free shipping. Real precise  products. check them out.http://www.amazon.com/Bessey-WSM-9-7.../dp/B0006694FA  http://www.amazon.com/Bessey-WSM-12-.../dp/B0006694FK
Reply:Northern Tool has many diffrent types...http://www.northerntool.com/webapp/w...70_12495_12495...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-30 04:24 , Processed in 0.117666 second(s), 18 queries .
