oxy/ace practice at school
发表于 2021-8-31 22:42:27 | 显示全部楼层 |阅读模式
I started welding school on tuesday. Here's some samples of oxy/ace welds.3/32 R-45 rod#1 torch tip.10psi of acetelyn20 psi oxygen.Neutral flame,sonI have never gas welded before this tuesday. It took me a while to get the hang of it, torch angle, the right amount of heat, distance from the flame to the base metal, adding enough filler rod. My instuctors seemed to like my results. They are by no means perfect but it's a start.Eastwood TIG 200NAPA 83-315 MIG
Reply:Good to see other schools are still teaching OxyFuel Best way to learn how to read a puddleMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:X2 on Wookie's comment.Looks pretty good to me, considering the time you have been at it.   Keep practicing and experimenting.  Different torch angles to control heat.  Rod to cool the puddle, etc.  Once you master gas welding, the other processes get a whole lot easier and TIG will come to you in a snap.RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:Have never done it... but if it's anything like tig, you could probably work on your filler wire control. Learn how to "dab" it better. If that makes any sense.
Reply:Originally Posted by akabadnewsHave never done it... but if it's anything like tig, you could probably work on your filler wire control. Learn how to "dab" it better. If that makes any sense.
Reply:Originally Posted by Rog02X2 on Wookie's comment.Looks pretty good to me, considering the time you have been at it.   Keep practicing and experimenting.  Different torch angles to control heat.  Rod to cool the puddle, etc.  Once you master gas welding, the other processes get a whole lot easier and TIG will come to you in a snap.
Reply:Originally Posted by WookieWeldingGood to see other schools are still teaching OxyFuel Best way to learn how to read a puddle
GMT+8, 2025-12-30 04:22 , Processed in 0.119514 second(s), 18 queries .
