Stick electrode brands?
发表于 2021-8-31 22:42:27 | 显示全部楼层 |阅读模式
So there is the obvious difference between lincoln excaliburs and radnor. What i want to know is between the normally priced electrodes what brands stand out. I am mostly concerned with 7018 and 6010. That is what i mostly use, but i havent burnt a whole lot of rods yet of different brands, mostly radnor. What is your opinion?2 invision 456 mp, 456 pheonix, 3 hypertherm 1250, Hypertherm 45,Dynasty 200dx, Millermatic 210 w/ spoolgun, Bobcat 250, 12vs extreme, slugger dry cut saw, slugger mag drill, O/A rig, Piles of tools
Reply:Man what a BIG can of worms you just opened. Stand back and hold on.I've been running Hobart 7018 & 6011 mostly lately though, not sure how they compare price wise with the Lincoln rods.Last edited by Bistineau; 09-04-2013 at 04:59 PM.
Reply:I've always had the best results with lincoln excalibur, especially when running 7018.  The beads come out smooth and the slag practically falls off.  I've used hobart a lot as well, doesn't run as nice as Lincoln in my opinion  and is a little harder to chip off.  Those are the only two I've really used.
Reply:If you're using an inverter welder, I've come to the conclusion they like different brands of rod. My Everlast Power Arc 200, and a Longevity Stickweld 250 I ran performed really well with ESAB's 10P-Plus 6010, and ESAB's Atom Arc 7018. The Stickweld 250 also liked Lincoln's Excalibur 7018. My Lincoln V350-Pro runs ESAB's 10P 6010 best, and ESAB's Atom Arc 7018. My SA-200s could care less what brand of rod you run with them.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:6010 - 5P red rodLo-hy - I love McKay, but hard to find. Esab Atom Arc and Lincoln Excaliber run great too. I bought 150lbs of Lincoln Jet LH78MR and it runs fine.I don't run inverters, yet. That said, the most incredible arc I've seen was Esab Atom Arc on a Lincoln V350 Pro. I think I'm gonna have to pay a visit to CEP's shop some time!!!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-man6010 - 5P red rodLo-hy - I love McKay, but hard to find. Esab Atom Arc and Lincoln Excaliber run great too. I bought 150lbs of Lincoln Jet LH78MR and it runs fine.I don't run inverters, yet. That said, the most incredible arc I've seen was Esab Atom Arc on a Lincoln V350 Pro. I think I'm gonna have to pay a visit to CEP's shop some time!!!
Reply:Originally Posted by PachecoweldI've always had the best results with lincoln excalibur, especially when running 7018.  The beads come out smooth and the slag practically falls off.  I've used hobart a lot as well, doesn't run as nice as Lincoln in my opinion  and is a little harder to chip off.  Those are the only two I've really used.
Reply:Originally Posted by 96708Dang my lws only has hobart and radnor. Ive never even heard of mckay. What is the lincoln jet ones for?
Reply:I've used 99% Excalibur rods. I I find they strike and burn very nicely, but I have heard of people boasting of better re-strikes with other brands.I used some Esab 7018 also. I found that the arc didn't adjust from corner to corner in a groove like the excal rods do. I found this out on the root pass of my DOT test  I should have practiced with it anyway, my stupidity there.IW Local 580 NY, NY
Reply:Originally Posted by 96708So there is the obvious difference between lincoln excaliburs and radnor. What i want to know is between the normally priced electrodes what brands stand out. I am mostly concerned with 7018 and 6010. That is what i mostly use, but i havent burnt a whole lot of rods yet of different brands, mostly radnor. What is your opinion?
Reply:lincoln 5p+ for 6010 hands down  and esab atom arc 7018 with lincoln excaliber 7018 being my second choice for 7018pretty sure your LWS will order you what you need Radnor stuff is JUNK as has been said alreadyMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Lincoln Excalibur 7018 has the best puddle definition of any rod I've tried, period.And I've run them on a Tbolt, IA250, ACDC tombstone, Dynasty,TA300, TA95, XMT and Maxstar 150 so far.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:We used all kinds of $hit rod.            NOW, we got them buying ALL LINCOLN , everybody agreed on it.
Reply:Cool thanks for the input i will have to try and make a special order.2 invision 456 mp, 456 pheonix, 3 hypertherm 1250, Hypertherm 45,Dynasty 200dx, Millermatic 210 w/ spoolgun, Bobcat 250, 12vs extreme, slugger dry cut saw, slugger mag drill, O/A rig, Piles of tools
Reply:Who makes the rods for Radnor? The Radnor Mig accessories are made by Miller
Reply:Originally Posted by johndeerefarmerWho makes the rods for Radnor? The Radnor Mig accessories are made by Miller
Reply:Hobart 418 from a sealed tin for my 7018, and Lincoln 5p+ or Hobart Pipemaster for 6010. I hate Excalibur dosent restrike for $hit a.d the flux falls off if you look at it the wrong way, other than that it welds nice. McKay is just fancy Hobart wire.
GMT+8, 2025-12-30 04:24 , Processed in 0.071121 second(s), 18 queries .
