Welding magnesium, what filler?
发表于 2021-8-31 22:42:26 | 显示全部楼层 |阅读模式
Can you use 4043 or 5356 to tig weld magnesium?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I would say no, you might be able to get away with it if your dealing with an aluminum alloy with a lot of magnesium but probably not with your typical mag casting. Magnesium filler wires are available
Reply:NO get proper mag filler and be sitting down when you see the priceMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:How would you weld aluminum to magnesium?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleHow would you weld aluminum to magnesium?
Reply:Originally Posted by shovelonYou don't. Magnesium can be an alloy to alum, but that is it.
Reply:We use AZ92A filler wire for welding Magnesium castings.And as has been noted it's pretty expensive.We usually use it in 2.4mm diameter, I've found the 3.2mm filler a bit too big and not as user friendly as the 2.4mmRegards Andrew from Oz.
Reply:I tried it in a pinch with 5356 since it has a higher mag content and the mag filler a bit pricey.  It did not work, not one bit.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:McMasterCarr has it in half pound lots. Not cheap, but doable."ERAZ 61A Magnesium1/16"36"1467972A8187.27________3/32"36"667972A8283.98________1/8"36"367972A8381.60________ERAZ 92A Magnesium1/16"36"1467972A8487.27________3/32"36"667972A8583.98________1/8"36"367972A8681.60________"Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-30 04:04 , Processed in 0.073614 second(s), 18 queries .
