Thought I'd post some pictures of the D300 3+3 I bought in July. Hour meter says 927 hours on Kubota V1903 diesel.
Reply:Simple Green and tear down
Reply:Marked and welded up the holes lincoln stamps in all of the face plates and Red-d-arc covers up. Last edited by Root Pass; 11-26-2013 at 02:51 PM.
Reply:Last edited by Root Pass; 11-26-2013 at 02:54 PM.
Reply:Stainless Steel Lincolnditioned style exhaust. It's now 5 13/16" shorter but no pictures. Last edited by Root Pass; 11-26-2013 at 04:24 PM.
Reply:Absolutely gorgeous!!Hobart 125 EZHobart Handler 140Everlast STH 160Generic 210 Amp Welder/GeneratorHobart Air Force 500i plasma cutterChinese 50 amp plasma cutter! Youtube Channel : Henrymac100
Reply:Bad to the bone and ready for 100 years of service.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Thanks guys. I love it!
Reply:Wow!!! Root Pass, that thing is bad aass!!! Did you buy it direct from Red-D-Arc? If you don't mind, what did you give for that?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:That's purty!How did you fill those holes?Did you do the paint job yourself?
Reply:My welding partner lives in NC and saw it on Craigslist in Ashville. I bought it for $3500 and it came with 100' of brand new 2/0 cable and 100' of 1/0 cable. He went and picked it up for me from one heck if a nice guy. I filled the hole with a MIG wire feeder. On the larger holes I used a piece of copper from an old 200amp fuse. It's about 2-3" long 1 1/2" wide and close to a 1/4" thick. It makes a good back stop! I didn't paint it. One of the guys at church worked part time for a body shop guy that started doing side work. They were slow so he ended up taking it to work. He painted it there and baked it in their oven. It only cost me $400 including the paint($125 a quart). I wanted to keep the cost down so I asked for a minimum of body work.
Reply:Sweet deal! Nice job on the resto too! "Every choice you make will effect at least one other person"
Reply:more work involved than the pictures show. nice job. 927 hours on that kubota isnt anything. alot of life left in that machine.
Reply:Fantastic!Miller Dynasty 200 DXMiller CP-300 with 30A feederHypertherm Powermax 900Oxy-fuel w/Harris torchesScotchman Glide-in bandsawMonarch 10EE latheEmi-Mec Autoturn latheDeckel FP2NC milling machinePro-Tools 105 Bender
Reply:Looks great! Does it weld as good as it looks?
Reply:Really looks great. Kudos.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Very nice. I think I may have done a lot of the welding that went on that machine. From the hinge barrels down to the base. Including the lift bale. Enjoy.
Reply:Nice works!! do you still have the paint code?? thank
Reply:I had asked the painter about the color when I first started picking up the painted sheet metal. He never gave me a solid answer. The most I got out of him was that it was a GM color that is used on their European autos. I have him DuPont B8012 (Medium Opal pearl) and I guess he found the closest he could find.One Step Ahead Of The Home Owners Association.
Reply:Ok good, I'm about to paint mine!! I really like your paint!! Will try to find find it!
Reply:Nice!!! |
