Lincoln Vrtex 360
发表于 2021-8-31 22:42:14 | 显示全部楼层 |阅读模式
Does anybody have experience with Lincoln's VRTEX 360 training?If so, what have you discovered about it?What did you think f it?Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:We have one at the votech I go to I've ran 6010 and 7018 with it. It is a lot different then actually welding at least I think it is. It is kinda cool to see your score all broke down after you make a weld tho. ranger 225
Reply:I remember (barely) when I was in class, I felt a lot of pressure to make the best bead I could every time, and it seemed too much a waste of time to experiment to see what would happen if I purposefully did things wrong.It seems this would give the student a risk free opportunity to violate best practices, so he could witness what happens while it is happening, and maybe be better able to react to it when welding.Not to replace the real thing, but sort of give a preview of what he will experience.Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:It's a decent way to introduce someone who's never seen an arc to welding. As far as training new welders- there is no substitute for real blue light.
Reply:We have one at school. It is never used. My instructor says the school wasted 60kHF 98233 Stick/TigHF  95136 PlasmaEastwood TIG200Eastwood MIG250Damn, I cut it twice already and it's still too short!
Reply:Its like playing call of duty to learn how to shoot. Cheap and not very helpful.
Reply:Originally Posted by iongarIts like playing call of duty to learn how to shoot. Cheap and not very helpful.
Reply:You dont learn how the rod actually burns down or how striking an arc is. Yeah you can use it for travel speed but its not nearly the same as welding. It was a very glitchy machine and constantly broke down.
GMT+8, 2025-12-30 04:24 , Processed in 0.100735 second(s), 18 queries .
