Can anyone tell me what this is called, and where to find it??
发表于 2021-8-31 22:42:07 | 显示全部楼层 |阅读模式
Guys,  can someone tell me what this hose is called and where to find it?  I need about 500 feet of it.  About 5 years ago I found a couple of 250 foot rolls of it, but now I cannot for the life of me find it again???  Any insight would be greatly appreciated.  It's 1/4" ID and 1/2" OD.  I am in the process of gearing up for a HEAP of TIG welding so I need quite a lot..........will be running 6 torches quite a ways from the machines.  If anyone has a better suggestion for hose, please tell me, but I really like this stuff cause it's very light, pretty tough, and very flexible................and reasonably cheap.Thanks in Advance--Matt Attached Images6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Just ran out to the shop and checked.      Anchor Brand      Gas Type = Argon    Grade = R    Hose I.D. = 1/4 in    Inside Outside Diameter = 19/32 in    Length = 25 ft    Hose Pressure = 200.00 psi [Max]    Operating Temp. = -40°F [Min], 212°F [Max]    Material = Synthetic Rubber    Case Color = GreenThat's the spec on it.  Should be available from any LWS or industrial hose supply.Last edited by Rog02; 09-13-2013 at 08:03 AM.RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:Here you go.http://www.mcmaster.com/#welding-hose/=ohllbvBe careful though. In the welding world GREEN means OXYGEN!!!
Reply:It's called argon hose, they sell it at welding supply stores.
Reply:Hey Expat, here is one place I remember seeing it.http://www.ramweldingsupply.com/prod....mcic?c=340&m="Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Dunno about shipping to Ghana, but for all my rubber and plastic needs I use Hannah Rubber Co. http://hannarubbercompany.com/Home_Page.phpThey can probably supply anything you need.  Local company for me and GREAT service.  Goodyear hose is listed here:https://dl.dropboxusercontent.com/u/...trialHose.htmlpage 247500 foot spools.It appears the fittings need to be sourced separately.  Hannah may be able to supply these as well.  I have never purchased welding fittings through them, just hose.Western Ent.http://www.westernenterprises.com/en.../fit_inert.phpRogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:Go into any welding supply store, and just ask for "quarter inch oxygen hose."
Reply:Originally Posted by jakeruGo into any welding supply store, and just ask for "quarter inch oxygen hose."
Reply:Thanks guys, I have ordered a 700 foot roll from McMaster.............should see it in 2 months, hopefully.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:They probably have an Airgas in Timbuktu.You could have mentioned you were in Ghana, not everybody checks a poster's location, ya know.
Reply:you could get away with some barbed fittings and pulling an new oxy acetylene hose apart if that helps and you have some laying around.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-30 05:39 , Processed in 0.120943 second(s), 18 queries .
