.035 MetalCore Welding Wire
发表于 2021-8-31 22:42:03 | 显示全部楼层 |阅读模式
I have about 30 spools of .035 metal core wire I am looking to sell. I am asking $40.00 a spool. They are 25 pound spools. Their classification # is E70C-3M. Very nice running wire. I am in Bryan ohio if anyone might need some. I should also say that this wire falls under AWS A5.18.only thing worse than an ugly woman is an ugly weld
Reply:What brand?  I like metal core!David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:made by filler metals inc. good running stuff, i just have too much of it.only thing worse than an ugly woman is an ugly weld
Reply:OK, I can't find any thing on E70C-3m.  -6M, yes, but 3M, no could you point me to a link?This is a Metal Core wire that runs with gas correct?  Almost NO slag?  Goes on like butter in a spray type transfer?David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:yes gas shielded. any silicon islands are directed to the center of the face of the weld instead of sticking to the weld toes. makes it way easier to remove it.only thing worse than an ugly woman is an ugly weld
Reply:I found it, C/25 for gas.  70,000 Psi tensile strength.......DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I have never heard of filler metals inc.Do they manufacture their own wires or just redistribute like Radnor?
Reply:HI weldrwomn   I bought one roll to try.  If it works, I will buy more.  I could find no "cheat sheet" for it so I will have to wing it.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Hi David I was just curious about the manufacturerTo my knowledge, I have not welded with a wire of that particular designation. I would be curious on what you have to say about it.
Reply:A little bit of info from another vendor.http://www.select-arc.com/product_sh...ect70C-3.shtml
Reply:if its a corp. (inc) you should just goolge them if you dont get anything stay awayor try BBC
Reply:I did google them, I really didn't get anything useful
Reply:THANKS Sandy, that even has a cheat sheet, but not for .035.    More info than I had. I didn't know you even could run metal core in short arc.  David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:We use the .045 in our shop . Great stuff we lay it down heavy with no slag or spray. Very easy cleanup and paintover.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:I've used it as well in shop. I like it better than mig
Reply:David!I would be interested in your thoughts on this wire as well!I could probably use a few rolls of it, if its a good wire for mild steel in the 1/4" to 1/2" thick category, and also if its a multiple pass wire for thicker runs!Did I read right that it works good with 75/25 gas?#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-30 05:47 , Processed in 0.097553 second(s), 18 queries .
